Question about Garden
My snowblower will start but will not move. - Garden
  • Carl Rock
    Carl Rock Jan 01, 2020
    Make and model?
    Master:
  • 385 Answers
How long have you had it,,will it even get into gear, if not then it sounds like it cud be a transmission problem, you can find anything you need here,www.discountbargainprices.net
Posted on Dec 31, 2019
Anonymous
SOURCE:
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snowblower stuck in gear
The issue here is likely related to the "linkage". Linkage is the parts (often a cable or metal rods) that connect the shifter to the actual part(s) inside the snowblower that need to physically move to change speed and direction of the machine.
You'll need to carefully inspect the entire linkage to locate missing or worn cotter pins, bolts, etc. You may need to open the underside on the snowblower to inspect and access the entire linkage. These are typical parts that are used to keep the linkage connected to the shift handle and internal wheel assembly. The linkage isn't usually complex - often a pin or threaded portion that passes thru a hole in an assembly - that is held in place with a cotter pin, bolt, etc. Simply move the shifter so that the linkage can be secured properly and you should be "good to go".
Feb 14, 2014 | Craftsman Tecumseh Snowblower 7hp...
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Huskee snowblower help
so you only have idle speed ?
it must start hard
there is a governor but not normal to go out of adjustment
check carb linkage and springs
does your thottle lever move anything when you move it ( as far as throttle plate or any linkage?
Oct 14, 2013 | Tecumseh Snowblower Snow Blower Starter...
2410 troy bilt snowblower wont start...no spark
unplug the switch to make sure it isnt just stuck in off position *(internally stuck while the switch will still move) If it starts you can unstick the switch with some WD and a couple back and forths with the key.
If you still have no spark you are gonna need a new coil.
Dec 31, 2012 | Garden
Track snowblower won't go into high gears
snowblower moves in 1&2 but won't move in 3&4
Jan 10, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
41 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
