Question about Nokia Cell Phones
How to take apart my Nokia 2 v - Nokia Cell Phones
What is the solution cause my nokia phone 2330c-2 buttons stoped to work?
Please change the key pad ,
Click on following bellow link for apart your mobile.
http://www.formymobile.co.uk/2330disassembly.php
Purchase the keypad from ebay or any website follow the link.
http://www.alibaba.com/product-gs/200798092/Mobile_Phone_keypad_for_nokia_3230.html
Hope it will help you.
Jan 10, 2011 | Nokia Cell Phones
My nokia x3 buttons have stopped working apart from the power button can you help me resolve this please
my nokia x3 buttons have stopped working apart from the power button can you help me resolve this please. The beep sound is present while navigating the keys.
Aug 11, 2010 | Nokia X3 Cell Phone
Power button on nokia not working
Take the phone apart and unsolder the switch,
Solder 2 wires to the to the (+) and (-) plates on the mainboard let the 2 wires come out via the on/off button cavity, assemble the phone again.
When you touch the unisolated ends off the wires for a second: "the phone will go on!"
touch again: "the phone will go off!
This is tested and working solution!!!
Please vote!!!
May 09, 2010 | Nokia N70 Cellular Phone
Is not charging
you need a right charger, so dat will charge!
Mar 21, 2010 | Nokia 3310 Cellular Phone
I have china mobile. nokia E65 modal. when i go to into apartments. then my mobile signal is down. display shows ''emergency''. how to solv this problem? how to format? and what is restore settings...
Good day,
i have an european nokia N80 and many times i have the same problem you mention, i believe it's not a problem of your mobile but it's about the apartments you go into as rebar reinforced concrete structure could cause the a Faraday cage effect. In my case i didn't really solve it but you can try to play with your network settings changing the favourite type of network the mobile will use (gsm, or 3G). To answer to your question about how to format i suggest you to install nokia pc suite and nokia software updater; with these 2 pieces of software you can back up your mobile content (you can choose what's going to be saved and what's going to be lost) then perform a software update even if the program tells you that you have already the latest O/S installed on your mobile.
Aug 02, 2009 | Nokia Cell Phones
Nokia 8910 ribbon cable
Some ribbon cables are simply inserted into the connector - no soldering or clamping
Mar 17, 2017 | Nokia 8910i Cellular Phone
Do U Know Wux Wrong. . .
special tool for taken sliders apart but sounds like the ribon for bottom end to top end might have came apart this is a dealer fix simple for them hard for the public
May 13, 2008 | Nokia N95 Cellular Phone
Changing Cases on Nokia N76
hi jess_r86
there's a video on youtube doing this YouTube - Nokia N76 hope this helps.
riz.
Apr 22, 2008 | Nokia N76 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
