Computers & Internet Logo
Rick Brosnikoff Posted on Dec 29, 2019
Acer ax3400-e4502 will it update to windows 10 or should we buy a new desk top?
Dheeraj Kumar Shukla
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Jan 28, 2020
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
677
Points
It will be update so please don't buy new desktop
5 Related Answers
Anonymous
  • 336 Answers
  • Posted on May 31, 2008
SOURCE: transfering my outlook and emails folders from my old desk to my new acer desk top
No because outlook is an installed program in your older computer so you can't transfer install programs from one hard drive to the next.
Sorry
RCF
Anonymous
  • 71 Answers
  • Posted on Nov 02, 2008
SOURCE: unable to get remote desk top computer to work on acer aspire one
I think you're trying to connect to your office computer from home/somewhere else.
If that's the case, make sure you have done the following :
  1. Your VPN Session is connected
  2. Your Office IT Administrator allowed RDC over VPN
  3. Your Office Computer RDC is enabled
  4. Your User (local or domain user) having administrative rights or allowed to connect to RDC session
  5. You got no firewall blocking RDC connection or remote registry
To check if you already connected to your office VPN, launch command prompt and try pinging your office computer name or IP Address. As an example if your office computer name is PC-100 and IP address is 192.168.1.100 then you will issue : ping PC-100 or ping 192.168.1.100. If you got ping reply than you're good to go.
To Enable RDC on your office computer there are 2 ways :
1. On your office computer, right click my computer > properties > Remote > Enable Remote Desktop
2. Via remote registry :
- Start > Run > Regedit > Enter/Return
- On registry editor, go to File > Connect Network Registry > Type in your office computer name > OK
- On your office computer registry, browse to : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server, find the key "fDenyTSConnections", double click it and change the value to 0
You should disable your windows firewall or 3rd party firewall for easier configuration. You can;however set up exception on your firewall but will need some knowledge to do that.
Hope it helps.
mrahul_009
Manoj Misal
  • 83 Answers
  • Posted on Mar 15, 2009
SOURCE: user manual for acer desk top computer
go to below link and search Manual for ur PC...
just choose ur pc Model than they will show u all drivers and manual...
http://support.acer-euro.com/drivers/downloads.html
If it work Pls RATE ME if not reply me
thaks
Bye
Saigua
Steve Nordquist
  • 982 Answers
  • Posted on May 02, 2010
SOURCE: Where to download drivers to update the BIOS for my IBM desk-top
Ha! Old OS, old URL; possibly just an old desktop not up to the task of running WinXP.
It's a new BIOS you'd flash your system with, and probably a push between your motherboard's BIOS having an update (you'd go to the mobo's maker's site, e.g. that of ASUS, Gigabyte, Intel, etc.; read the screen-print on the board; to get the update) and telling WinXP to install anyhow using a handy force-install option.
reggieguia
Reginald Villodres
  • 329 Answers
  • Posted on Mar 21, 2011
SOURCE: i have a new touch
try install microsoft essentials. this is a antivirus for all microsft. http://www.microsoft.com/Security_Essentials/
AX3400-E4502 Motherboard Manual
https://www.google.rs/quality_form?q=AX3400-E4502+Motherboard+Manual+torrent&hl=en&client=opera&hs=DSN&channel=suggest
How do I fix my sound on my acer AX3400?
Try looking in your sound mixer settings for the default audio. Make sure it is set to the stero jack and not the digital coax. altho windows is suppose to automacticly detect what is pluged into the sound card, many times it does not and will default to the digital coax. These settings are found under control pannel
Hope this helps
How do i fix sound problem on Acer AX3400-U3032 Desktop
You need to optimize your system. Use a system utility software RegInOut -- includes several features which allows the PC users to fix drivers issues. It improves system performance by removing junk files and fixing registry errors. Then update you sound drivers.
Hope it works for you.!!!
I need a restore cd for Acer AX3400 Desktop Windows 7 version as the hard disk has become corrupt on the restore part. Help pls
There are a number of companies advertising on the web selling this sort of disc. I have never used them and don't know if they work. Maybe you would like to find out?
Just google acer startup disc
Hope that helps.
Acer desktop crashed following a windows vista system pack 1 upda
try to go to this link this might help you removing the Vista SP1
http://www.mydigitallife.info/2008/02/06/windows-vista-sp1-file-removal-tool-vsp1clnexe-reclaims-disk-space/
http://blogs.techrepublic.com.com/window-on-windows/?p=655
Good luck
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
