I'm trying to choose between the panasonic s65 and Samsung 63plasma. Some keep telling me Trying to chose between pan.S65&Samsung 63 plasma to buy. Keep being told Samsung has problems and not good support.Can you offer any info? [
Go to the menu button on the printer (choose the option above "OK" button), choose "Network" (Get this option by keep pressing the Menu button until the "Network" option is shown and hit "OK")--"Network Configuration"--"Print". Page #2 of the printout will shown the WPS pin number of your printer. There are two WPS serial numbers shown, but the one on the bottom called "WPS-Pin for NFC" worked for me.
chose the input from the lcd operation on screen manual that is proper for the signal you are using (example) hdmi, AV, or TV. when you choose the correct input selection the lcd will show what ever signal you are sending it.
I have the same car (2007 S65) and can't find the 2nd Battery. My trunk has a small spare tire and both sides of rear panels accessable from the trunk have electronic modules, but not battery.
take your mp3 off the usb and go into the settings, you should find settings for the usb connection , ,, one of the options should be highlighted , chose the other one and try again,,,, your mp3 was set to charge only just pick the other setting and it should work. that happened to me once
Hi, If you choose the format option in the camera's menu it will basically format your memory card or the internal memory if you don't have a card. Formatting will erase all your pictures, try not to choose this option until you have backed up all your pictures to a computer.
NO FIX AVAILABLE OTHER THAN REPLACEMENT OF MONITOR
TUBE TYPE MONITORS HAVE CATHODE RAY GUNS IN PITURE TUBE THAT PRODUCE COLORS WHEN THEY START TO SHORT OUT THEY PRODUCE BLOCKS ON THE SCREEN AREA AS YOU HAVE DESCRIBED
I Suggest an lcd flat panel replacement MADE BY PANASONIC SONY OR SAMSUNG BUT CHOOSE A MONITOR FIRST THEN CHECK REVIEWS ONLINE TO INSURE THE MOINTOR YOU CHOSE HAS NO HIDDEN ISSUES before you buy
