SOURCE: The bag from my lawn mower keeps coming off. How do I prevent this?
You can call the company for help, or even make sure that the screws that are attached to the strap that goes around the bag are really tight.
But THE best solution there is duct tape! It works on everything!!
just roll it until it is secure, it may look poor or whatever, but it should keep it secure for ages!
SOURCE: Craftsman 5.5 Gold mower will not start
YOUR PROBLEM IS SIMPLE.
FIRST OF ALL THE HOLE IN THE PRIMER BUTTON MUST BE THERE TO POP BACK OUT EACH TIME YOU PRESS IT NOW AS TO THE GAS COMING OUT OF THERE
THE FLOAT IN THE CARB IS STUCK IN THE FILL POSITION AND WILL NOT LIFT ONCE THE BOWL IS FULL TO STOP THE GAS FROM FILLING OR YOU HAVE A PIN HOLE IN THE FLOAT ITSELF.UNDO THE NOT ON THE BOOTM OF THE BOWL WITH THE LAWN MOWER TILTED ON A 45 DEGREE ANGLE SEE IF YOU CAN MOVE THE FLOAT UP AND DOWN IF IT IS FREE MOVING SPRAY THE WHOLE AREA CLEAN WITH CARB CLEANER AND REASSEMBLE TRY TO START ,IF STILL THE SAME PROBLEM YOU WILL NEED TO REBUILD THE CARB AND INSTALL A NEW FLOAT
SOURCE: 10 year-old lawn mower Craftman Eagle 1, 6.5 horse
sounds like the main jet is blocked. remove it and run a piece of fine wire through it and retest.
SOURCE: on my Baumr-AG Tornado 650EX 4-stroke lawn mower my starter cord will not retract
There is a spring under the dog ear plate it's probably broke there's a hook on one in of the spring that hooks on to the housing and and the others end hooks to the starter pull it's self take bolt out of center of pull start and take a look be easy the spring sometime likes to fly out its not a typical spring per say it's a coil spring wound up
