I cleaned the glass in my GE oven.
Take the door off and undo the screws holding the handle and set them aside. There were two screws in the bottom edge as well. The glass had clips to and bottom on both the inner and outer door. I removed both panes and sprayed them with Easy Off oven spray. The grime to the inner surfaces came off very easily. I cleaned the ledge that separated the glass as well. Then I rinsed them well and reassembled everything.
It is a "sealed unit", not intended to be cleaned
SOURCE: Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
SOURCE: Inside glass of zanussi oven
Works on Zanussi ZBF 660 X Built In Oven.
To remove door:
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
SOURCE: I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
SOURCE: How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
