Ol?!
Voc? sempre deve calcular aproximadamente 40 minutos de forno m?dio (180 ° C) para cada quilo de frango (peru sem recheio) e pode usar a tabela abaixo como refer?ncia, pois o tempo de cozimento varia de acordo com o tipo de carne. forno e o tamanho da Turquia. E se o peru estiver recheado, aumente o tempo de cozimento em 30 minutos.
4 kg 2h45m
5 kg 3h20m
6 kg 4h
Espero que ajude.
SOURCE: I've never roasted a stuffed
sorry more of a technical website tha n a how to cook website, but htere might be a cooking guide in your use and care manual, if not i would try googling that answer
SOURCE: Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
SOURCE: can you cook a stuffed turkey in the roater oven
Yes, similar timewise to a regular oven. But it depends on the size of the turkey, if stuffed you definitely want to
check the fit- you need about an inch all around including the top to
get good cooking. Any place it touches the sides it will tend to
overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14
minutes per pound. In my experience this is too hot. I use 325 for 4 to
4 3/4 hours at 325 for an 18 pound unstuffed turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end
point temp (down quite a bit from a few years ago), but if you stuff,
that has to be in the middle of the stuffing, and the turkey will
overcook somewhat while it gets there. It adds about 1-2 minutes per turkey pound if stuffed.
All experts agree that turkeys
cook better and safer if unstuffed, so considering that you will have
to make an extra pan of stuffing to have it for everyone, you would be
well advised to cook your turkey unstuffed and use some of the
drippings to flavor the pan of stuffing while the turkey rests.
SOURCE: i have a elecric delonghi oven with a gas hob with
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
