SOURCE: Iphone touch-screen
Solution i tried on Unlocked 1.1.3 and 1.1.4 versions. Just follow the steps they have been explained really easy way. Dont think this is too hard. Just follow them it will work:
1) download WinSCP on your PC (google it) and run the application
2) download new general.plist file on laptop
3) download OpenSSH on your iphone (its not show on iphone but its there so dont worry)
4) connect the laptop and iphone through the same wireless network and both will have separate ipaddress.
5) write the ipaddress from the iphone (Settings>Wifi>network details to which you are connected to shows you the ipaddress)
6) Goto laptop on WinSCP type the ipaddress of the iphone in host name field and username:root and password: alpine and then hit Login.
7) it will open like an explorer view of your iphone files on laptop then click on root left side. Click Applications> preferences> replace the general.plist file with the one you downloaded. Done the major part.
8) unplug iphone click Settings> General>Touch and reduce the senstivity to 0. 0 gives you the highest touch sensitivity.
9) Now be happy it works....
SOURCE: Genius MousePen tablet 8x6 Isn't responding to the pen.
Have you tried replacing the Pen battery? Maybe it died.
SOURCE: Touch screen and stylus pen not working
I just had the same problem and found a solution on another thread on this site. Clean the screen really well with Windex and dry it. Check all 4 edges for crumbs that might be lodged in there. I found one tiny crumb. I dislodged with a small nail file (gently!), wiped the screen off and then it worked! I didn't even bother recalibrating it. When I turned it on and went to the sign in screen, it was working fine. The original post also said to try "milking" the screen in case pressure had caused it to stick. Press gently with your thumb on the screen in various spots around the screen, then try again.
SOURCE: graphire4 pen registers without touching pad
It's meant to. So you can move around the page without selcting anything.
SOURCE: When you press your name
Welcome to Fixya
The screen needs to be re-calibrated if the stylus pen is not responding. Please see procedure below:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
