Google search of this issue seems to indicate it is rather a common one.
They are working but the app reports they are not. Sounds like a connectivity issue between the part of the app which gets status of the devices and the devices reporting their status.
Google the device and "reporting not connected in the app" and you will see a lot of posts.
SOURCE: I am having issues with my nexus s. I keep getting
I think you mean optimus S :). There are a couple of things I would try to do to fix this problem. first I would try to check and see if the browser cache is clear. Setting up you browser to dump the cache on exit is a good practice. If your Optimus is rooted you can also use one of the many applications on the market that can clean out your cache for both the internal and external memory automatically. If all else fails a clean wipe will always do the trick. The Optimus One has had some file system hiccups and this will almost certainly fix your problem. The google market place should install all of your lost apps. Hope this solves your problem. kidromulous
Testimonial: "he was very helpful and descriptive. his solution for wiping the phone cleared up the ptroblem. it also made the phone move faster as well. "
Corrupted software
It
isn't often that Apple gives specific directions about how to fix your
problem! Restoring the iPad will erase everything on it, so make sure
everything on the iPad is stored elsewhere prior to restoring. To
restore, connect your iPad to a computer with the latest version of
iTunes installed. When your iPad appears under the devices menu, click
the restore option under the summary tab. If you haven't backed up your
data already, choose the back up option from the pop up window. Click
the restore button to restore your Touch to factory spec.
God bless you
Hi Joe Valrose, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
ask them yet
https://home-automations.net/smart-life-...
or
https://upgradedhome.com/smart-life-outl...
or ask the community here
https://community.smartthings.com/t/inte...
