On the back of the phone ?
speaker holes
to let the sound out
https://www.phonearena.com/phones/LG-Stylo-5_id11198/manual
page 24
SOURCE: Water shooting out bottom holes
This normally means that the iron is not heating up enough check that you have adjusted the temp so it is not as the water will either come out of the bottom when not hot enough to steam or when the jets get dirty and need cleaning.
Thanks J
SOURCE: LG Bottom Freezer problem with ice
its behind the freezer back panel cover under the evaprator which looks like a silver honey comb
SOURCE: water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
SOURCE: My friend has a 2006 Charger and it started
if it's a 2.7 engine,this is the water pump weep hole..water pump is leaking and needs replacement..these engines are tricky to time..a time consuming repair
SOURCE: I have a Badger 5 InSinkErator and it is
There should be no leaking to the outside of the motor. If there is a weep hole, it would indicate there is a seal problem between the cutter blade shaft and the motor. Contact ace hardware and see if theycan give you a little more information on this unit.
