SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
SOURCE: How do you remove the
Actually there should be a little door you can access at the bottom front to clean out your pump filter, I'm including my washers pictures. 1) You first open the little door at the bottom. You do not need any tools, just something to drain the water in to. 2) Unscrew the hose closure, put your hose down into the drain bucket. Drain all the water out, you may have to empty the bucket so you can get the hose lower next time. 3) Next unscrew the filter itself. Get anything out inside the hole, in my case it was a toothpick, I take a paper towel and dry out any grit or hair. 4) Put your hose closure back on, it is held in a clip, Then screw the filter back in. That's it. I would also recommend cleaning out the drawers that hold soap, bleach and fabric softener. Also clean around the rubber ring, it will help your washer last longer. Hope this helps you
SOURCE: Samsung VRT Steam FabriC Softener not dispensing
My fabric softener intermiitently was left with clear water in the tray. The serviceman replaced the tray which did not fix the problem, he then replaced the valve assembly. That fixed the problem for about a year and now I am experiencing the same problem. Being the unit is now out of warranty, I purchased a valve assembly and replaced it but what I found in the process was that the real problem was that after removing the filter screen where the hose connects I found a SECOND mesh filter that was plugged up. I removed it with a needle from the edge so I didnt damage the screen. I think you could also just used a spray bottle with some water and a Q tip to clean. I wasted $50 on a valve assembly, but I did discover this second filter screen that is not mentioned in the user manual. Hope this helps someone because I have not seen this solution posted anywhere.
SOURCE: What does dc Flashing on my Samsung aqua jet dryer mean?
A "dc" error occurs when a Samsung washer is unable to spin due to an unbalanced load. Redistributing the items inside the washer and pressing the "Start/Pause" button typically clears this error
SOURCE: What does Code nf on washer machine Samsung vrt model mean
NF indicates no water flow. This could mean that the incoming water valves were shut-off, the incoming water flow is low, or that the washer didn't detect the water flow into the washer correctly. If the drain hose is too low, the washer could fill and drain simultaneously. This can also cause the problem.
First if the washer is not getting any water, then check your shut-off valves and the hoses. Disconnect the hoses from the washer and place a bucket under them. Check the flow by turning on each valve for a bit. Clean or replace the filters at the shut-off valves and in the washer. Consider replacing the hoses. Some anti-flood hoses will reduce the water flow if they detect leaks. Make sure that the hoses are not kinked. If the water flow is good at the shut-off valves, then the inlet valve may have failed in the closed position.
If water is filling the washer, then the problem is in the water flow detection system. This could indicate the small reed switch is damaged, the air tube to the reed switch is clogged or that tube has a hole in it. Some washers check for fill by the change in the drum weight. This signal may not be reaching the control unit due to a problem with the sensor or the wiring.
If the washer is filling and draining, pull your drain hose up. It is below the washer fill level. This creates a vacuum that will drain the washer.
I hope this helps.
