SOURCE: Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
SOURCE: I have an old Royal 501Plus typewriter.
check if typing wheel is the correct one for this machine.
you have to make sure the bright side of he correction has to face you
unaasp192
SOURCE: TA Royal 503 typewriter with a print wheel that is not aligned
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Next clean the main rod that the carriage goes back and forth on, it sometimes get very sticky. Then place a couple of drips of oil on. This should work wonders? Best John ex OEM trained mechanic
