Kitchen Appliances - Others Logo
Alice Harrison Posted on Dec 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Instructions for janoel 24 incubator - Kitchen Appliances - Others
Terry
Level 3:
  • Kitchen Appl... Master 11,377 Answers
  • Posted on Dec 26, 2019
Terry
Level 3:
Answers
11377
Questions
Helped
4625187
Points
152765
Https://www.tiojuan.es/app/download/5812768878/Janoel+24.pdf
https://www.google.com will also provide additional information, such as a facebook group and Amazon comments.
1helpful
I have a GQF 1502 incubator with digital control and the humidity number stays at 97 but when I put a hygrometer inside the unit it read 47, so what could be wrong.
There could be several reasons why the humidity reading on the digital control is not accurate. Here are a few things you can try:
  1. Calibrate the hygrometer: The first thing to do is to make sure that the hygrometer you are using to measure the humidity is calibrated correctly. You can check this by placing the hygrometer in a sealed container along with a wet sponge or cloth for a few hours. The hygrometer should read close to 100% humidity. If it doesn't, then it may need to be calibrated.
  2. Check the humidity sensor: The humidity sensor in the incubator may be faulty or dirty. You can clean the sensor with a soft cloth or replace it if it is damaged.
  3. Check the water level: Make sure that the water level in the incubator is sufficient. If the water level is low, the humidity will be low as well.
  4. Check the ventilation: The ventilation in the incubator should be set to allow for proper air exchange. If the ventilation is not set correctly, it can affect the humidity level.
  5. Check the room conditions: The room conditions, including temperature and humidity, can affect the humidity level in the incubator. If the room is too dry, it can affect the humidity level in the incubator. You may need to adjust the dehumidifier or add a humidifier to the room to maintain the proper humidity level.
2answers
I’ve lost my instructions for JANOEL24 incubator. Can you help?
I found a link to a site that has 'instructions' but the debate was over whether this machine was a genuine or knock off. Either way the instructions were up on a post. Hope it helps -
Janoel Incubator 24 Real or fake
1helpful
What is the incubation period for Hand, foot mouth disease
  1. Hand foot mouth disease incubation period The usual period from initial infection to the onset of signs and symptoms (incubation period) is three to six days. A fever is often the first sign of hand-foot-and-mouth disease, followed by a sore throat and sometimes a poor appetite and malaise. One or two days after the fever begins, painful sores may develop in the mouth or throat.
I need instructions for a janoel 12 egg incubator please i have lost mine
Here are instructions from another website along with various links to download manuals and lead you to other forums talking about egg incubators:
Operating steps:
1. Put the mesh with the rail(big mesh)(fig.1) into the incubator.
2. Put the moveable egg tray (fig.2) on the mesh with rail, please do it within the rail.
3. Put the egg tray grille ( fig.3) into moveable egg tray according to size of egg for incubation.
4. Put the hatching egg into moveable egg tray(fig.5) for incubation, pay attention that after each egg is put into the grille, there should be 5mm clearance at least for convenient turning of hatching egg, inject 100ml water into the base after the hatching egg is put, check once for every two days so that the incubator is not short of water. Every water injection shall not be more than 100ml, take down the date of placing hatching egg so as to well control the hatching time. It's best to place the incubator on 60-100cm for convenient insertion of link rod.
5. When closing the cover(fig.7) , the link rod must insert the shifting slot of moveable egg tray, so that the egg tray can shift normally.( in other words, the cercley thingy coming out of the top with a rod in it has to be attached to the egg tray by putting the rod into the egg turner square hole to make sure that the incubator turns the eggs well)
6. Switch on the power supply after closing the cover, and set temperature according to push-button instruction and incubation technology. If the user has no time to care about the temperature, the temperature can be set at 38'c from the first day of hatching, and it can be set as 37.5 - 37.8C since the following day of hatching.
7. It moves to hatching tray 3 days earlier than incubation period for other poultry
8. It usually takes 3-4 days less than the number of incubation days for egg tray replacement, replace the egg tray once one or two hatching eggs are seen hatched, take all of the hatching eggs off from the incubator firstly, then take the moveable egg tray with mesh with rail out, check the water level, then put the hatching mesh( fig. 10) and egg tray in and put the hatching egg on the egg tray, shown as fig. 11.
9. After closing the cover and switching on the power supply, the hatching situation can be observed.
This was originally posted here: Janoel 12 incubator help
Best wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
1helpful
Does anyone have an instruction manual for the JN8-48 Egg Incubator?
http://www.backyardpoultry.com/forum3/download_vault/JN848%20user%20guide01.pdf
Where can i buy chicken's eggs incubator in South Africa?
we are specializing fully automatic chicken egg incubators form 88eggs, 176eggs, 264eggs, 352eggs, 440eggs, 528eggs, 880eggs, 1056eggs incubator our incubator fully computer control and 96% hatching rate also include hatcher we deliver country wide visit us www.chickenincubator.co.za
you will find all our incubators and sizes in our website
How hot does this heat tape get up too?
Sounds like you are trying to hatch chickens. The heat tape is designed to keep pipes from freezing, and will not be warm enough for an incubator. Try a heating pad or electric blanket, or if you are really serious, you could just BUY an incubator
Instructions and recipes for salton yogurt maker
Instructions For Salton Yogurt Maker
It will provide a stable temperature for incubating the yogurt. In this article you will find the best instructions for Salton Yogurt Maker
http://ezinearticles.com/?Instructions-For-Salton-Yogurt-Maker&id=1192702
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
