Dont know your model but usually things work that way. If your remote is on cable box function then is used to change channels on your cable box. Once you switch remote to tv mode then channels function is used to switch channels on tv. Tv must to be either in over the air tv (antenna) or unscrambled cable channels if your tv is equipped with internal decoder
SOURCE: Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
SOURCE: LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
SOURCE: remote contol will not work
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
directv remotes are not guaranteed to work w/ all types of TV's. when programming remote to TV, make sure you are holding down MUTE and SELECT both at the same time for about 4-5 seconds. until it blinks twice at the top of the remote. also the slide switch must be under the "tv" mode on the right hand side. the website i provided is by directv, and has a list of their codes for the brand of tv that you have.
if you are trying to program a remote to a directv box, and none of the codes are working for the directv box, contact directv to have them send you a new remote.
