Computers & Internet Logo
Anthony Cardenas Posted on Dec 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP ER27 Display has constant 1 inch borders.
To be clear, this is a 27" HP monitor. The "Auto" function on the display does it's 'adjustments' but the boarder remains. The latest monitor drivers and video card drivers are also installed. Nothing I've tried removes the large black boarders. Thanks for reading this! Anthony
goneforever.
Level 3:
Top Expert:
  • HP Master 14,531 Answers
  • Posted on Dec 29, 2019
goneforever.
HP Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263716
Points
66315
27 ER you meant? a new monitor?
er27
PLUGGED IN TO WHAT? you posted to computers , IS IT .?
NO OS stated running windows 98?
what port used, vga,dvi,dp, hdmi cable.
no adaptors? on cable either end or inside cable.
we can not see what you have before you eyes.
it must be told first.
ALSO , no screen content stated. at all
windows desktop not filling screen?
or using say VLC running old DVD 4:3 video.
that will always not fit modern wide screens.
what is on your screen , what is there, exactly even a photos works 10x better posted.
NO PC stated
no OS stated
NO screen content stated, doing what seeing what/
2 Related Answers
Anonymous
  • 141 Answers
  • Posted on Apr 04, 2008
SOURCE: dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Anonymous
  • 203 Answers
  • Posted on Apr 16, 2011
SOURCE: well i have a 23
Dear User,
Good Day!
Please use the auto button in you monitor then it will automatically adjust the resolution of your screen. Please feedback us what happen.
Thank you...
My HEWLETT PACKARD ER27 DISPLAY has constant 1 inch borders.
Are you using onboard graphics or a dedicated graphics card?
Well i have a 23 inch LG monitor and im using the recommended resolution of 1920 x 1080 and its not fitting the screen. therers 1 inch black border on tob and bottom and 3/4 inch black border right and...
Dear User,
Good Day!
Thank you...
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Display smaller than screen capability
GO TO CONTROL PANEL ,,DISPLAY OPTIONS,,, CHANGE YOU RESOLUTION
1helpful
My hp w1907 monitor is constantly auto adjusting every 1 or 2 seconds. Make it stop.
Good morning! Auto adjustment occurs when resolution or refresh rate of the display changes. Check your display setings in OS. Set them properly according to product operations manual. Update your display adapters driver. Also check your VGA card or motherboard display port & try using a different cable. try pluging the monitor to a different computer or plug in a different monitor with your motherboard or VGA cards display port. best regards
I have a black border on top of my screen
There are two things which could have caused this. One, the Monitor settings have changed or the computers display settings have changed.
1. Resetting the monitor to default.
Push the 'MENU' button to open the OnScreedDisplay system and display the main features menu. Push the - and + buttons to move between the function icons
Use the buttons to highlight 'Factory Reset' (this returns the settings to the factory preset values for the selected group of functions)
Detailed instruction available at http://support.dell.com/support/edocs/monitors/E153fpb/En/controls.htm
2. Checking the desktop display settings.
Right click on the desktop and select properties, click on settings and make sure screen resolution is set to one of the following 640 x 480 or 800 x 600 or 1024 x 768. These are the only ones supported by the monitor
If both this fails. Then the monitor is nearing end of life
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Display is off-center
Try the Auto adjust button on the monitor buttons first.
If the entire picture of the computer is showing you can try to shift and stretch the picture through the menu button.
2helpful
2answers
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
