Evaporator fan also works
You may need a check Freon level to see if its low , usually if u have low Freon level you can touch the condenser fan rails and they should be cold because when it has Freon and it liquefies into gas it creates heat hence the coils will then get warm and hot, if they are hot or warm it may not be a low Freon level issue? I would also check the freezer thermistors , see pics there may be more than 1 thermistor in freezer section , u can also check the compressor ur self to verify as not all appliance techs are reputable or knowlagable
Frigidaire freezer that will not get colder that - - defrost terminator thermistordefrostterminator-undefined-undefined-5.jpgr-undefined-undefined-5.jpg" alt="defrost terminator thermistordefrostterFrigidaire freezer that will not get colder that - - thermistor locationboththermistors-undefined-undefined-9.jpgbr>
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
SOURCE: PLHS69EGSS1 Freezer not cooling properly but Frig is OK
try to check the defrost thermistor and also make sure that the unit is working with the right FULL LOAD AMPERAGE by looking this we will know if it has exact refrigerant in the system.
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
SOURCE: Freezer is cold, main food compartment is warm
the evap fan probably stopped working because of the shorted defrost thermostat. if you remove the freezer drawer you will probably see frost build-up on the back wall. what you need to do is remove the back wall and manually defrost the coil with a hair dryer. have some towels handy. once the ice is melted you will need to replace the thermostat or this will happen again. you should buy a new thermostat before the repair so you know what you're looking for. hope this helps
SOURCE: Frigidaire Model FRT18DRH
Did you have them to check the freon gas pressure. The defrost timer could be bad that you replaced. Try turning the knob on the timer to see if the frig will kick the compressor on.
