Bypass the Power On switch. This will tell you if the problem is the Power On switch, or the Power Supply.
Has nothing directly to do with the Power On switch, or it's wires.
A jumper wire is used on the 24-pin ATX main power cable's connector.
Jumps from the green Soft Power On wire to ANY Black wire,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The preferred jumper wire is a paper clip.
The paper clip is straightened out, then bent into a U-shape.
The top of the U is wrapped a few times with black plastic electrical tape.
This tape area is for your fingers and thumb to hold onto.
Turning the U-shape upside down the 'Legs' are what is used.
One leg goes down into a socket hole with the Green wire.
The other leg goes down into a socket hole with ANY black wire.
ALL Black wires are Ground wires.
The BACK of the 24-pin ATX main power cable's connector, is where the wires go into it.
The leg of the U-shaped paper clip, goes down into the socket hole with the Green wire, RIGHT NEXT TO THE WIRE.
Right next to the green insulation of the wire.
The 'leg' has to go pretty far down in the socket hole.
It has to go far down in the socket hole, and TOUCH the metal terminal at the end of the wire.
The other leg of the U-shaped jumper wire has to go down into a socket hole, with ANY Black wire in it. It also has to touch the metal terminal at the end of the Black wire, down in that socket hole.
[All wires going into the 24-pin ATX main power cable's connector, end in a metal terminal,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-USThe Back of the metal terminal is the left side. The tangs on the left side, have not been crimped down on a wire yet. (Insulation)
The jumper wire touches this side.
The Front of the metal terminal is the right side. The opening of the
metal terminals, and Front side, can be seen in the middle photo of the
Playtool link,
Power Supply plugged into power; 24-pin ATX main power cable plugged into the motherboard, as shown in the photo to the far right in the Playtool link above.
The contact period of the U-shaped jumper wire is Brief.
No more than 2 seconds. The Power On switch is a Momentary Contact Switch.
IF, the Power Supply comes on you have a bad Power On switch.
IF, the Power Supply does NOT come on you have a bad Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
