Question about Samsung Audio Players & Recorders
I have Samsung HT-Z310, Ic and capacitor blew up I replaced and the fuse but still no power on what could be the problem
3 Suggested Answers
Anonymous
SOURCE:
SOURCE: Digital In on Samsung HT-Z310 no sound
Optical into your XBOX 360? If there is a connector that you are using to convert it, I was start by replacing that.
Posted on Jun 04, 2010
jonsnell4
JonSnell Electronic
  • 30806 Answers
SOURCE: Please I have Samsung home theater HT-Z310.Which got shot...The power IC blew up and scathered,that i can't find the number number on it.please help me with it
Download a service manual. You will find the information you need to order the spares required to repair it.
Don't forget to repair the parts that caused the issue.
Posted on Sep 04, 2018
Sep 04, 2018 | Samsung Audio Players & Recorders
Please i have a samsung home theater HT-Z310. Which got shot.. the IC blew up and scathered,that i cant find the number number on it.please someone should help me with it. Reply are sms +2348167674444
IC's just do not blow up - something drove it to such drastic action! Best bet is to get a hold of a schematic for your device and also check out parts in the environs.
Sep 21, 2017 | Samsung Audio Players & Recorders
Samsung LN40B500P3FXZA TV has no power. Replaced bad 3.1A fuse but it blew again when attempting to power on. No obvious bad components (blown capacitors). 6.3A fuse is still good.
Since that I have not schematic diagram of your tv... I cannot figured you out the exact part number of those components that caused the problem, but the possible reason why the fuse are always blown when you turned on the unit? because there are some bad filter capacitor, rectifier diodes and power IC regulator in primary power circuit section.
Nov 08, 2016 | Samsung Televison & Video
I have a samsung HT-Z310 home theatre. I left plugged and when light was restored the power ic blew. So i replaced and the power came back on but immediately it comes on it say protect.
That's the power supply board isn't it. Have you checked the main power amp board? For when the power board failed it might have taken out the main power amp with it!
Jul 25, 2016 | Samsung Audio Players & Recorders
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Apr 03, 2011 | Onkyo TX-DS777
Samsung HT-Z310 will not power on after power outage and unplugging and holding the stop button for more than 5 seconds does not resolve the issue, any suggestions?
Open the system and replace the brown fuse with the number 382 on it. It's right where the cable plugs into the power board.
Sep 09, 2010 | Samsung HT-Z310T Theater System
Jun 04, 2010 | Samsung HT-Z310T Theater System
Ht-z310 states protect. Tried to reset the machine but it didnt work? Samsung said it could be overheated however, the device hasnt been on in months.
The channel that has a dc voltage above .2 volts is bad. Measure from each terminal to the chassi . These unit are board replaceable. Replace the amp board.
Jan 01, 2010 | Samsung HT-Z310T Theater System
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
