I bought a brand new LG tv today. I'm watchin a hockey game and the tv blinks off for about one second and the next immediately comes back on. It isn't freezing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1200 posts to different brand TVs now. Pull up
older posts there. Blinking codes to LG Brand TVs are described in detail here.
Fixed.The tv Tuner signal board have a problems and the causes.U have some mechanical skills like take things aparts amd putting it back together again.Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.Or the tv shop,will repair by replacing this tv Tuner signal board for u.It should cost u about half the price of a new tv.
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Resetting the TV If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE: Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time. 1. Unplug the TV power cord from the power outlet. 2. Unplug any connected devices (DVD, Set-top boxes, etc...) 3. Press and hold the TV power button for five seconds. 4. Plug the TV power cord back into the power outlet and turn on the TV. 5. Open the on-screen menu to confirm that the TV is responding again. 6. Turn off the TV and reconnect the devices. 7. Turn on the TV.
tracey.....take the battery cover off the back of the remote....then go to the game system cons and open the front flap to the left of the cd slot (find the red sync button on the cons......press and hold the red sync button next to the batteries on the remote......now just press the button on the game system (do not hold button on the cons.)....watch the remote led lights on the bottom....when they are done blinking there should be a light left on (if this is the second cotroller, it should be the second light from the left that is on).
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
