Washing Machines Logo
Maio Posted on Dec 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 15 years old whirlpool washing machine. I notice lit on my clothes. Do I change the filter? If so where do I locate it?
Thomas Perkins
Level 3:
  • Whirlpool Master 15,088 Answers
  • Posted on Dec 20, 2019
Thomas Perkins
Whirlpool Master
Level 3:
Answers
15088
Questions
0
Helped
3389630
Points
54869
5 Related Answers
Bob Gemmell
Bobby G
  • 212 Answers
  • Posted on Sep 13, 2007
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on May 20, 2008
SOURCE: Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
A
Anonymous
  • Posted on Jun 23, 2008
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Anonymous
  • 481 Answers
  • Posted on Aug 04, 2008
SOURCE: Samsung washing machine filter
it has a self cleaning filter. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Anonymous
  • Posted on Dec 09, 2009
SOURCE: Lint Filter in Whirlpool Agitator washing Machine
I have a regular top loader and the lint filter is on the underside of the inner tub. You have to remove the inner tub to get to it. You might be able to find a service manual explaining this at appliancejunk.com.
Where do I find the filter on a Whirlpool top loader - our clothes regularly need re-washing as are covered in fluff?
have you check the outlet drain hose for blockage? go online check your wp model for built-in filter if any. if there is one you need the washmachine schematic show the location of the filter. most of the old machine may have a panel on the backside to access. this way you can get to the filter.
My Whirlpool Duet shrinks my clothes.
If you did not have good success with the unit - I would advise against getting another one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
2answers
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
I have a WF220, 1200 spin washing machine (3.5 years old and very little use) which does not complete the washing cycle. Each light comes on as the programme progresses until all the lights are lit...
You may find that the internal filter is blocked & that by stopping and starting the machine you are giving it extra time to complete the drain cycle. The filter is located at the bottom rear of the machine & is secured by a large hose clip to the bottom of the drum. Try filling the washer with no clothes in & then switching to the drain programme to see if the water drains properly
1helpful
2answers
Getting F02 error, machine stops part way in & beeps.
Thank you so much for posting your solution of the F02 error code. I was having the same problem and noticed that my clothes smelled like mold and I didn't understand why. Anyway, my husband "cleaned the filter". He found four socks.
Awhile back, I noticed that I was missing a lot of socks. One day I pulled the gray flap in the washer and found around 15 socks! I now check that flap after every wash.
Again, thanks for posting your solution. It was an easy fix and it saved us $$.
2helpful
4answers
Excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
