Debbie Saunders Posted on Dec 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon printer won't print wireless from phone - it has been working but we had to change the internet router and now it says cannot communicate
Bill Boyd
Level 3:
Top Expert:
  • Canon Master 53,816 Answers
  • Posted on Dec 20, 2019
Bill Boyd
Canon Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948565
Points
172802
You will need to reprogram the printer to the new router or reinstall the wifi connection from the printer to the router
5 Related Answers
Anonymous
  • 124 Answers
  • Posted on Mar 08, 2009
SOURCE: Can't print from my mac to my canon mp980 wireless printer
Sounds like when you added xp you inadvertently installed new print driver on server.
Try rolling back driver. But may drop xp from printing.
Best solution network printer to router bypass server. Will require hard wire from printer to router. disconnect from server may need network card for printer.
Anonymous
  • Posted on Nov 05, 2009
SOURCE: canon mx310 won't print wirelessly from laptop.
The MX310 is not a wireless printer. I own it and have never seen that feature anywhere in the specs either. Try the MX860 (my roommate owns it and it's VERY nice).
Anonymous
  • Posted on Dec 09, 2009
SOURCE: Wireless printer causes loss of internet connection
  • i have the same problem
Michel Smith
  • 1218 Answers
  • Posted on May 05, 2011
SOURCE: Wireless Printer Setup
For installing a wireless printer on Windows XP, wireless router is an essential device.
Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network.
Since several computers or laptops will access the printer, it0 1is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
toptencombo_
router support
  • 3 Answers
  • Posted on Dec 04, 2019
SOURCE: Dell V510 printer worked fine wirelessly until we got a new Belkin Router
Router Tech Support Phone Number +1-844-456-4180 router support Belkin wireless router is not working Get belkin router setup as a company was the first in its field to launch a wireless router to share a single internet connection with multiple devices.
2answers
2answers
I just got a Canon Pixma MG5370, Im running an XP cp to network thru Netgear N300 then thru DSL, the N300 dangles a Netgear 8 port wired Switch. I cant get the dam printer to connect correctly to print,...
Set a static IP on the Canon printer
e.g.
IP: 192.168.x.x
Subnet mask: 255.255.x.x
Gateway: 192.168.X.1
DHCP should always be enabled on the router for your other devices to work.
11helpful
Canon printer won't print wirelessly
there is always a way to fix things,
it may be the settings in the printer itself. it does need to be configured to work on the network, you will need to see if it is on the network firstly. then setup ip settings afterwards to get it going, then a re setup on the computer.
If you would like additional assistance with setting it up I am available to do it with you on TeamViewer so you can watch what I do for next time.
Regards,
Adam
3answers
The printer's IP address most likely needs to be changed.
Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
Dell XPS won't connect wirelessly to my Canon MX340? I have a wireless router for the internet that I am using right now
have you configure your router to access your printer?. try to navigate on menu at the printer and locate any possible wireless connection opened, then just follow the screen guide on your printer to access wirelessly.
I have a Canon MP495 inkjet printer. I had a linksys wireless router and changed to a netgear wireless router. Since the change I am not able to print to the priter over the wireless network. Before the...
the printer must see the router, follow manuf. instructions, ( from printer especially. ( just a minor communications issue. al;so check and make sure both units are plugged in and powered up
3helpful
Canon MG6100 wont print and displays "A
Have you tried a "wired" connection to a different computer?
If the problem persists, then the printer itself is the problem.
Have you tried a "wireless" connection from a different computer?
This presumes that the wireless-configuration on the printer is correct,
and that the printer is "talking" to your wireless router.
Login to the router's web-interface, and check the status of all "wireless" connections,
to ensure that the printer has a valid wireless connection to the router.
4helpful
I have a Canon Pixma MX860. I have it set up to recieve communication via wireless. I has been working great. but all of a suddon when I go to print off my Mac Laptop, it pauses the printer and doesn't...
Cycle the power
If your printer was previously printing via wireless communication but can no longer do so, it may be necessary to cycle the power on the printer and Router / Access Point to restore communication. Before doing this, verify that the computer can communicate with the Router / Access Point.
On the printer, press the On button to power off the printer. Wait about 10 seconds, then press the On button to power the printer back on.
On the Router / Access Point, if there is a power button, press it to turn off the device, then press it again to re-power after waiting for about 10 seconds.* If there is no power button, you may have to disconnect the power cord / AC adapter. Check with the device's user manual.
* Wireless communication of all devices on the wireless network will be lost while you do this.
old marine
old marine
ZJ Limited
ZJ Limited
