The 5011 error is a general hardware error; if you have already verified that there are no paper jams in the printer, with a flashlight or other bright light, please check the paper feed and print head areas of the printer to verify that there are no other obstructions in the printer that may be causing the error
Canon Printer Error 5011 is kind of printer error usually occurs because of some problem in the cartridge holder that is stuck inside. This printer problem does not allow users to perform the scanning process.
Methods that fix Canon Printer Error 5011 Easily:-
Method 1: Perform Power Cycle.
Method 2: Check if Any Bits of Paper is Stuck in the Machine.
Method 3: Clean the Encoder Strip.
Method 4: Try Turning Off and Then Turning on the Printer.
blog - Canon Printer Error 5011
Hi Arev.
Canon printer error code usually occurs due to defect in cartridge holder which is completely stuck inside and as a result it generates the 5011 error code. ... This is basically a kind of defective Printers issue which restricts users to go ahead with the scanning process.
goto this link and have a read up.
https://www.canonprintersupport247.com/blog/how-to-fix-canon-printers-error-code-5011/
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: Canon MP490 printer error code 5011
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints. that should solve it!!
SOURCE: error code 5011 on my canon pixma m545 printer
If you wish to get some details; check the site linked here. Pull up older posts.......
http://electro-medical.blogspot.com/
