SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
SOURCE: sharp AR-R550n
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
SOURCE: sharp ar-m160 h2 error code
chack the fusing units the thermistor is open
&thermistor abnormality chack the harness and the
connector between the thermistor and the pwb
use simulation mode(# interaput c interaput )
preas the 14 toclear the self diagnostc dis play
