This error message indicates that the ink cartridges have been installed incorrectly. Take the following steps to resolve the issue:
1. Lift Printer cover
2. Check to see if the red indicator lights are on or not
3. If a particular cartridge isn't showing a red light, it means it was installed incorrectly. Remove the cartridge and make sure it is installed correctly and the orange cap has been removed before installing the cartridge
4. Press "Resume" or "Cancel" to verify that Error Code 1660 no longer appears
SOURCE: Canon MP830 error code 6A00
The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere.
2) there may some paper stuck somewhere around the printhead and or the purge unit or
3) there is a build up of gooey ink on the purge unit.
, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, plug the unit back in and hopefully it will work fine. hope this helps.dont forget to rate as fixyaa
thanks and Godbless
SOURCE: Canon printer IR2016J show error
i have a canon copier IR2016J shows me error code E007 please advise me on how to resolve it or rese it. thanks
SOURCE: Canon BJ - W9000 Error code: B800A
The BJW 9000 manuel is available as a free download I have downloaded it my self but dont have it at home why not do the same
Tony (withtrader)
best of luck
SOURCE: What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
