SOURCE: Projector gives off pink tint
when you have a tint on the projector its not a lamp issue, it is a connectivity issue you have to check the cables if they are connected firmly, or swap the cables with good known cables , if this doesn't help you have to send the projector to infocus repair center, since it is a DLP projector this may require engine /major repair
SOURCE: Green tint on entire screen of Sony KDS-55A2020.
When I was reading the instructions for this tv, It was saying if the projection bulb is reaching the end of its life you will get strange color changes. You can also reset your settings in the setting section. Go to your menu and go to settings and them picture. You can reset your picture to factory settings in this menu. Now you can reset in different modes also. You have to be in these modes to set factory settings. These are Vivid, Standard and Custom. Take a look. You can go to sony and it tells you haw to do all of this. You punch in your TV type and you can go into the instructions. I learned how to change my projection lamp.
SOURCE: Sony SXRD-KDS-R50XBR1
Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 and Call UED 1-800-648-6657 Just see which one has the lowest Price.
SOURCE: Why does my sony KDS 55A2020 seem like the
Seems there is a known quality problem that causes the "green haze" see this link http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
SOURCE: Need to remove a replacement lamp from a Sony 55
how do you install bulb into 55 in sony grand wega 3lcd tv
