SOURCE: whirlpool duet gas dryer ggw9200l need error codes
There is a mini manual located inside of the machine whith the codes and troubleshooting guide on some they are on left and some are under the top.
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
SOURCE: I have a Whirlpool WFS1273AW with error code F07
"F07" Motor Control Unit Error
The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). Check the MCU and the drive motor.
SOURCE: F07 error message
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: whirlpool f07
If i recall correclty the Error may be the filter. Check on the front panel on the lower section. If there is something clogged then the filter will not allow for proper water flow and it could shut the machine down.Also, check to see if you lines coming into the machine are not leaking. If the pressure is too low it can trigger the computer to shut down the machine. We had a pinhole leak in a line and it did the same.
