Sounds like back light problem. If you're aware in electronics, just proceed. if not seek assistance to any service technician.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
https://homenol.blogspot.com/
SOURCE: Samsung LA40R71BDX - Black screen, No picture but had sound
LCD screens are monolithic (one piece) components. They cannot be repaired, they can be replaced. One site I found for replacement info is http://www.screentekinc.com, they even have DIY info if you are so inclined. There are many other sites; do a search on "lcd repair"
SOURCE: samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
SOURCE: "melting" screen image
the problem is the backlight not lit evenly.
have the backlight inverter board checked for correct ac ht and if that is okay then u will have to replace the backlight.
SOURCE: REPLACING DIFFUSION PLATE/PICTURE SCREEN
i need help to replace front diffussion plate and clear screen
