Is this O-ring new or used? Would you write back and explain the application? There isn't much you can do with used O-rings that have been exposed to petroleum products. If the O-ring is new and is used in a low pressure water environment. There is a way to shrink the O-ring. A normal rubber O-ring can be cut and super glued back together. I recommend a new razer blade or scalpel. The better the two fases match up, the better the bond. If you need more details, instructions, hints or have other questions. Please feel free in writing back.
