SOURCE: Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
SOURCE: Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
SOURCE: connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Testimonial: "cheers, have a good year."
