SOURCE: I have a vivicam 5022 and need instructions
The 5024 manual is at
http://www.vivitar.com/products/21/VC5024%20User%20Manual.pdf
I suspect it is very similar to the 5022 manual.
SOURCE: vivicam 5022 user manual
Owners Manual here: http://www.vivitar.com/products/310/ViviCam5022.pdf
SOURCE: my vivicam 5022 turns then beebs twice and like falls asleep
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
If this response helped, please post a rating for me. A rating of "Very Helpful" would be appreciated . . .
Testimonial: "it didnt work cleaning the battery case but i didnt try the new battries but i still think it will work.i going to need profeshional help"
SOURCE: i have a vivitar vivicam 5022. will a lexar 256
It most likely will but it will not store a lot of pictures due to the pixel count of this camera
SOURCE: flash will not turn on on my vivicam 5022
This happens when you are in close-up mode. Move the switch on the side of the camera to show the 'mountains' - this will fix it.
