It means you should contact your local Panasonic servicer and report a code 3 message.
Videos claiming to fix
https://www.google.com/search?q=Model+dp-mb536.+What+does+%27call+service+3%27
SOURCE: Panasonic DP-8020P Machine Maintenance count reached.
yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
SOURCE: And what do we do
The code can be reset in service mode, LBP fuser reset.
E04-02 indicates a jamming problem in the fuser unit, usually accordion jams. Correct the fuser problem prior to resetting the code.
https://printcopy.info/?l=en&mod=erc&brand=Panasonic&model=DPMB300
Service 03 = fuser unit (the hot bit on the paper exit that melts the toner into the paper) is not heating up. Most modern laser printers have fuser units that are replaceable by the customer. You should be able to find a supplier for the unit. They normally come with full fitting instructions.
