SOURCE: Need instruction manual for Durabrand HT 395
Go to http;//audio.manualsonline.com maybe there you find it.Good luck.
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
SOURCE: I just bought the 52
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Testimonial: "worked like a champ!"
SOURCE: samsung LED UE46B7020 tv wont play sound through my HT-C5500
press the top right hand button on the remote for the ht-c5500 untill its display reads "D.IN" (Digital Input)
