Televison & Video Logo
Posted on Dec 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG Plasma TV Model 50BP560B 50. The HDMI port no longer works no signal and there is only one of them. I can't seem to find a main board for that TV anywhere. Any ideas of what to do?
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
  • Posted on Dec 12, 2019
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297222
Points
3055
You still can use component input.
5 Related Answers
skotkolr
Scott Hill
  • 558 Answers
  • Posted on Apr 30, 2008
SOURCE: Broken HDMI port
its a soldering job and you need to remove the board from the tv, not easy and not for the faint of heart
Anonymous
  • 53 Answers
  • Posted on Mar 08, 2009
SOURCE: how many Main Boards are in the Philips 50
the Philips 50'' Plasma TV model 50pfp5332D/37
has only one main board
has many sub bords supporting tat main board
sabreusa
AAA TV Service
  • 272 Answers
  • Posted on Nov 09, 2009
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Chi Chu
  • 8457 Answers
  • Posted on Jun 22, 2010
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Anonymous
  • Posted on Feb 13, 2011
SOURCE: i have a panasonic 50 inch tc-50px24 plasma tv. i
blinkin de red led tv panasonic plasma
2answers
LG 60PN6500-UA broken HDMI port and clicks when power on
It will most likely go away when you fix the board. I suspect there is a logic system in there looking for that port and is not finding it.
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at www.tvrepairworld.com
2helpful
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
1helpful
2answers
HDMI PORTS DONT WORK
You will need to replace the main video logic board, its part number is either EBU60852909 or EBU60852911. These two board are direct replacement parts. There are several boards available on Ebay such as this one: http://www.ebay.com/itm/LG-46LD550-UB-Main-BPR-Total-Assembly-EBU60852909-subs-to-EBU60852911-/150895037335?pt=US_TV_Boards_Parts_Components&hash=item23220b8b97
2answers
My HDMI inputs no longer work. The other inputs are ok. I hooked in a dvd player with HDMI out to make sure it wasn't just my satellite receiver and still it just says no signal. What can I do? Thanks
The only solutions u can tries is to unplug tv,satellite receiver box and plug it back in like about an hour later for the tv to reset itself and the sattellite box receiver to reboot and upgrade it softwares.Than go into the tv Menu go into the video setting and reset the whole tv Tuner signal board.This solutions have great chance for all the HDMI inputs to work again.If not have the same problems,sorry than those HDMI ports on the tv Tuner signal board are shorted and dead.These HDMI ports are putting on by a wave soldering machine when they are put onto the board.These HDMI ports can't be replaced individually or buy parts for it,almost impossible to replaces parts by hand soldering equipments either.The only solution now only is to buy a whole refurbish tv Tuner for the replacement,if u have to have those HDMI inputs for your tv,can't used other inputs to handle ur tv need to functions the tv the way u wanted.U some mechanical skills,like can take thing aparts and putting it back together.Yes.Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
1helpful
The HDMI inputs on my tc-p50x1 will not work at all. Both component inputs work, but all three of the HDMI seem to get no signal. Is there a fuse I can replace, or do I have to replace the entire...
No,the HDMI connections hubs are just a few small components parts that was put on by the wave soldering machine and it is on and surface mounted by soldering fussion to the tv to main tv Tuner signal board and funsction as one board,can't replaces these HDMI hubs by itself,it very hard and almost imposible to do so by hand soldering equipments and these HDMI components hubs they don't sell out as individual consumer parts any way.Tries tv unplug,replug it back like about and hour later for the tv to do a resetting itself back to the factory setting.Than go to the tv menu go to PICTURE setting go down to do a resetting to do a resetting to all the funsctions of the tv Tuner signal board.Now all ur HDMI hubs should be working again.If not,the whole Tv Tuner signal board mut be reolaced.Try website like Ebay.com to buy a whole refurbish main tv Tuner signal board for the replacement.
My tv wont connect thru hdmi any longer
If you have only been using one cable it may need to be replaced or the HDMI port on the television may be broken. Check the port and make sure it is clean and if it still dose not work speak with a local tv repair shop
Broken HDMI Port for HP-R5072
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
Hdmi port
I have a 50 inch and recently had to have the main board replaced d/t the IR receiver was failing intermittently. Since they replaced the main board, one of the two HDMI is doing the same thing (picture, no sound). When I spoke to service they felt the issue was related to the replacement board and will be replacing. The weird thing is the picture is not quite right + no sound. Usually with HDMI it's either all OK or not OK at all. In any event, my problem seems to be the main board.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
