SOURCE: vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
SOURCE: Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Testimonial: "Plug and outlet are ok, well drop it off at best buy to fix. Thank you."
SOURCE: Thin vertical red line on my LG 50PC56
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
SOURCE: Samsung UN46B6000 LED TV Had it
I have the same exact issue. I had mine for about the same amount of time, i can't believe a $2000+ TV brake that quickly.
Did you ever get it fixed ? If you did, how much did they charge
Thanks !
