SOURCE: Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: the tv goes on but the apps display with netflix,
Try restetting the TV by unplugging for 2 minutes then retrying it. If it still fails then there is most likely a failure on the main board in the TV
SOURCE: Philips HTL5120 has no sound when using lg tv 50lb6100 youtube/netflix apps
There isn't a firmware upgrade for this TV is there? Sounds like a firmware issue?
Do a hard reset to this set and check. If it do not help you, contact the authorized service center for RCA. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
discuss the problem with netflix technicians
