I may be guessing, but here goes. Make sure all the ink cartridges are seated. In Properties, got to Advance - have your settings checked off as follows: Spool print documents so program finishes printing faster, Aart printing after last page is spooled.
Clean the heads in printer, maybe a sllightly dirty cartridge opeining.
Other than above, I don't really know the correct solution.
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
SOURCE: Removal of Pedestal for Toshiba Regza 32HL67U
more than likely it is a Philips and there should be four marked with arrows
SOURCE: Where can I find a
try jimmyshop.com
Encompass Parts Distribution. 1-800-638-3328
Look on EBay under Eletcronics
SOURCE: The size of the pedestal base screws of an apex 32
Cannot find service manual for this TV, but they will be Metric screw M4, M6, or M6 that you can get them from HD or Lowe's for about 25 cents each, so for less tahn $5 you can try different sizes and lengths.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
