Hi pls can someone help me with solutions to error code c5352 on bizhub 250 after I solved error code c2557 it now display this
    Top Expert:
  • Office Equip... Master
  • 30,421 Answers
3 Suggested Answers
6ya staff
SOURCE:
Giamma Giamma
  • 12 Answers
SOURCE: Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Posted on Mar 20, 2009
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How do I solve c2557 error ?
Hi
I found your error code and suggested remedies here:
Error Codes Konica Minolta bizhub 250 Code C2557
This site is very useful as by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a pdf format Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 09, 2015 | Konica Minolta bizhub 250 All-In-One Laser...
Errorc2557
It is my pleasure to guide you.
Konica Minolta 250 Error C2557 is Toner Density sensor problem
Problem: code C2557 - Abnormally low toner density detected Black TCR Sensor
Sounds like something a technician should take care of. Most of the information I could obtain says that the
Solution: Replaced 4038-R729-00 Hopper Drive Assy (C250 part compatible with C252 )
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 13, 2011 | Konica Minolta bizhub C250 All-In-One...
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta bizhub 350 error code c5352 the machine is not workking now plzzzzzzzzzzz helpppppppp
Cooling Fan fault. To clear open and closer the front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 08, 2010 | Minolta bizhub 350 Black and White Copier
Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
hi,
Bye.
Mar 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
29 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
