Although non-structural cracks don't pose a structural threat, they can still allow water to seep into your home. Repair methods include: Epoxy crack injections - First, a surface patch is made using an epoxy bonder. Second, the crack is injected with a 2-part epoxy, waterproofing and reinforcing your foundation.
Foundation cracks can be a concerning issue, as they may indicate structural problems or water damage. The appropriate care for foundation cracks can vary based on their size and underlying cause. Here are steps you can take:
Assess the Situation:
Size and Type of Cracks: Measure the width and length of the crack. Generally, small, hairline cracks are less concerning than larger, wider ones.
Location: Note the location of the crack - whether it's on an interior or exterior wall, basement, or elsewhere.
Hairline Cracks:
Sealant: For small, hairline cracks, you can use a concrete patch or sealant designed for foundation repair. This helps prevent moisture from entering and worsening the crack.
Follow Manufacturer's Instructions: Ensure you follow the instructions provided by the manufacturer of the chosen sealant. It typically involves cleaning the area, applying the sealant, and allowing it to dry completely.
Larger Cracks:
Professional Inspection: Larger or wider cracks could indicate more serious issues. It's advisable to consult a professional such as a structural engineer or a foundation repair specialist to inspect the foundation.
Professional Repair: If the crack is deemed a structural concern, the professional might recommend methods such as epoxy injection, carbon fiber strips, or underpinning to reinforce and repair the foundation.
General Tips:
Monitor the Crack: Regularly check the crack's status, especially after heavy rain or changes in weather.
Prevent Water Damage: Ensure your gutters are in good condition and direct water away from the foundation to prevent further damage.
Signs That Warrant Immediate Professional Help:
Sudden or Rapid Growth: If the crack grows rapidly, it might indicate a serious issue.
Interior Damage: Signs of the crack causing damage inside the house, like doors and windows not closing properly or visible damage on walls, should be addressed promptly.
When to Seek Professional Help:
If you're uncertain about the severity of the crack or its implications, or if you suspect structural damage, it's crucial to get professional advice. Foundation issues are best addressed early to prevent costly repairs in the future and to ensure the safety and stability of your property.
Remember, while some minor cracks can be addressed by DIY solutions, larger or more concerning cracks should be assessed and fixed by experienced professionals to ensure the structural integrity of your home.
To repair a horizontal crack on the foundation, assess the damage first, scrub the crack with a wire brush, and remove any loose material or mortar.Inject epoxy or polyurethane into the crack to seal it. Give the material time to heal before looking for signs of cracks or water leakage.
Foundation repair probably resulted in some building movement before, during or after the event, causing the cracks in the drywall and lifting the tape in places. It would be better to removed the tape and begin again...
Sam, this is a foundation issue. It could be normal settling of the foundation or something more sinister. Seek professional help in diagnosis. If normal, a simple screw-top support pole in the basement/crawlspace below the wall will help to keep the supporting beams level. Once installed you just screw/jack it every few months.
You have to start outside. First regrade slope of soil away from foundation. Add a drain and tile to direct water away from house. If necessary dig down along foundation wall and add membrane. In the basement, add a sump pump to pump out water to keep moisture out. Clean basement wall, and add some waterproofing paint.
You're in the fixya's car fix section, but it sounds like you have a leak on the side of your house. That's bad. Is the foundation there, or is this above the foundation? Is the floor cement? if so, you may have a cracked foundation, or cracked floor. is there a window nearby? Water has a way of travelling. Even gets things wet that are not close to the window. You should trace this ASAP, cause you know that mould is to follow. Good luck
I have been a makeup artist for many years, having my own freelance business, working for Estee Lauder, and Lancome, and I strongly believe the best way to use foundation is to start with an exfoliated, clean, and moisturized face. Step 2: Find a foundation that matches your skin tone. Test it by applying a little on your jaw and blending it down toward your neck. The color should always blend into your neck. Thats how you know its the right color for you. Also, for best results, go for a foundation with medium-full coverage. Step 3: Apply foundation with a clean foundation brush, and blend down. Foundation brushes give you a flawless finish and you use less of your foundation that way. Sponges will only absorb the foundation, and fingers will give you uneven coverage, and spread bacteria to your face. Step 4: Apply a translucent powder on top, to help set the foundation, and than Blush or bronzer. Good Luck :)
I would contact Whirlpool directly to even see if it is possible. I tried to repair an acrylic tub one time and it didn't keep because the the constant water on it. If it can be repaired, they will give you the solution and info for a contractor that might be able to do the work if you can't do it yourself.
