?If my volume control doesn't work properly to do a factory reset. ?and factory reset in settings doesn't work. ?what other options do I have
    Top Expert:
  • Televison & ... Master
  • 30,785 Answers
Depends what machine you are asking about.
Posted on Dec 07, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Reset to factory settings
have you tried the companies website? Beltronics lists models going back 4/5 yrs!
Posted on May 05, 2009
mahhek
Laxman Bisht
  • 662 Answers
SOURCE: I need to reset my aspire 4315 series back to factory settings.
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Posted on Nov 15, 2009
hotaruseriza
  • 639 Answers
SOURCE: remote wont work and can't acess menu with tv
Turn your Sony Bravia on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
  • 2 Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
  • 3 Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
  • 4 Release the up arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • Read more: How to Reset a Sony Bravia TV ' eHow.com http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html#ixzz1Cn2noiTF
    Posted on Feb 02, 2011
    Anonymous
    SOURCE: Yamaha RX-V1000 volume control erratic, remote
    Hi.
    The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
    Manual for your receiver: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V1000.pdf
    It's not much but I hope this helps.
    D
    Posted on Aug 21, 2011
    gopakumarg43
    • 76204 Answers
    SOURCE: VOLUME CONTROL ON TV REMOTE CONTROL DOESN'T WORK
    Hello
    Your remote control needs cleaning. Just go to this link and see the details. OK.
    http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
    Posted on Nov 17, 2011
    My phone will not work. my number is ********** I need my samsung account user name and password to factory reset phone
    If you want To factory reset your device you can just perform the hard reset procedure without requiring you some codes.
    generally, you need to turn off your phone first then try these steps provided below;
    hold volume up + volume down + power button until samsung logo appear.
    from the factory settings, use volume button to select factory/wipe data option.
    Select yes on the appropriate option, depending on your phone model.
    then select reboot.
    for more accurate steps.. you can send your phone details to help you with.
    Feb 01, 2018 | Samsung Cell Phones
    The word demo how do I remove it from a AKASO tablet it's in big red letters?
    Factory reset it,
    Power off completely
    2. then hold down the volume down button
    3. holding the button press the power on button.
    4. if done properly you should have several android boot options
    5. select "Factory data reset"
    6. Done
    Note: if the volume down did not work, try the Volume Up button
    Oct 16, 2017 | AKASO Tablets & eReaders
    T l c brand t v volume stuck on high everything else on remote works cant lower it on t v either
    Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
    There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
    Jun 04, 2017 | Televison & Video
    Toshiba tv 40RV52U volume locked on HIGH
    Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
    In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
    Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
    May 31, 2016 | Televison & Video
    Viera volume stuck at full. Cannot lower volume from remote or from the button on the TV. Muting works from remote but no volume change.
    Fault with main board. Contact any service technician. Its auto-volume control circuit [electronic circuit] should be checked. If the firmware has been corrupted, this kind of fault can occur too. If so, a firmware update might be necessary. Try a reset first to this set, and check. To reset it into its factory settings, you have to enter its service mode option.
    To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
    Oct 27, 2014 | Televison & Video
    Panasonic sa ht940
    If you wish to bring the TV to its factory reset, you have to enter into its service mode option. You will get this facility by its service mode option only. But, you must have its original remote control to enter into its service mode. No universal remote will go. If you wish to get more details about how to enter, adjust and exit service mode, check the site linked here. Never attempt to experiment to get into the service mode, with a universal remote control. It will surely make some other trouble to the set. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
    Oct 14, 2013 | Televison & Video
    Techwood tv
    Jun 27, 2017 | Televison & Video
    How to troubleshoot galaxy young
    hi,
    i think you want to ask if how to hard reset your galaxy young...just do this procedure ...
    1. Power off phone
    2. Press and hold Home Button ( middle ) + Volume Up + power on button
    3. Wait for 5 second until Android System Recovery menu appear
    4. There are 4 options
    reboot system now
    apply update from sdcar
    wipe data/factory reset
    wipe cache partition
    5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
    6. After the process done, phone will reboot.
    Sep 30, 2012 | Cell Phones
    I cannot remember my unlock pattern on my samsung GT-s5360
    if you did not remember your unlock pattern ,you cannot open your phone anymore so you need to reset your phone like this...
    1. Power off phone
    reboot system now
    Sep 28, 2012 | Samsung Galaxy S GTI9000 Smartphone
    How to reset my samsung galaxy
    METHOD TO RESET GALAXY
    STEP 1: Switch off your phone, remove its battery, and then place it back.
    STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
    STEP 3: Now you will get a list of options to choose from. Which would be like:
    • Fastbook
    • Recovery
    • Clear Storage
    • Simlock
    STEP 4: There, choose the Clear Storage option.
    NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
    STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
    That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
    Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
    Televison & Video Logo
    Top Televison & Video Experts
    Marvin
    Marvin
