Question about Sears Garden
I need an impeller for a 20 year old sears snowblower. C950-52720-7
    Top Expert:
  • Sears Master
  • 34,293 Answers
Try sears website. you might get lucky
Posted on Dec 07, 2019
    Top Expert:
  • Sears Master
  • 55,370 Answers
Fixya does not sell old Sears parts.
6ya staff
SOURCE:
Anonymous
SOURCE: flame comeing out of muffler and sparks on 8 hp
clean out your muffler
Posted on Dec 29, 2009
agent91
Ned White
  • 2100 Answers
SOURCE: the impeller will not unscrew from the shaft. 20
Try soaking it overnight with blaster, the stuff works great, Take off the back cover, you should have two flats on the shaft to fit a wrench, If it won't go left, try right and see what happens.
Posted on Feb 25, 2010
thomascha103
  • 58 Answers
SOURCE: I need a manual for
MTD Yard Machine manuals are available online, but you'll need to locate and copy the model number and serial number, which should be on a model plate that looks like this:
When you have these numbers, click this link, and enter the information to download the manual for your snowblower:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10451&langId=-1
If you can't locate the numbers, or they are difficult to read, it would be best to call their customer service department. They will know which manual you need. They can be reached at 1-330-220-4683, or 1-800-800-7310.
Posted on Jan 13, 2011
drallim
  • 4088 Answers
SOURCE: i have a sears 179
Remove the fuel line from the carburetor and check for a thin stream of fuel running out. If it just drips, the fuel filter may be plugged. If fuel does stream out, then the carburetor may have plugged jets from stale fuel remaining in the carburetor after the last running. Remove the float bowl, and use spray carburetor cleaner on the jets. Running fuel system cleaner in the tank should help as well. Good luck!
Posted on Jan 27, 2011
jonsnell4
JonSnell Electronic
  • 30787 Answers
SOURCE: Removing a wash impeller on a Kitchenaid KUDSE124 dishwasher; about 20 years old.
Warm up the shaft first and use a sprocket puller.
Posted on Feb 11, 2017
Testimonial: "The basin it is mounted in is full of water; assuming use a baster or something to get water out? How do I get at shaft? All that is showing is the impeller and it is against the bottom of the separator."
Have a toro 2450 5 hp snowblower used to throw snow at least 8ft now lucky to go 1ft changed belt last year thought that was problem but didn't fix the problem any suggestions? Thank you
Just a thought. Is the belt tight or does it slip when you put pressure on it. Check and see if the impeller outfit is plugged. Mine did that and it was plugged with an old shirt I picked up in the snow. Can you turn the impeller by hand when the engine is shut down. If so could be a shear pin broke off in the impeller.
Dec 30, 2017 | Toro Garden
I am looking for a manual for a craftsman snowblower model c459-52101
go to sear web sight om line they will have one if its not five years old
Sep 03, 2014 | Craftsman Garden Tractor Snowblower...
CRAFTMAN snowblower 53688110
If it has the round shoot that narrows down to a square hole then this is typical. These sears models are horrible. They reduce the hole so you can't get you hand in there but they clog like crazy.
You can put Rubber fins on the Impeller blades and it will help greatly. GOOGLE " Clarence Modification"
Sep 08, 2013 | Garden
I have a sears 179 cc snowblower i have to run it on 1/2 choke the snowblower is only 1 year old.
Jan 27, 2011 | Garden
My Craftsman 5.0 horsepower 5 speed forward, 2 speed reverse snowblower has a problem with the auger. After using it this morning working fine now the auger isn't turning. It's about 8 years old and has...
If the blower (impeller) turns and the auger doesn't there is a 90% chance you broke the shear bolts that protect the auger gear box.
Look at your auger and you will find the bolts shown at the arrows in this picture are missing. Some snowthrowers will have two bolts and others like the new Craftsman will have four.
You can get new ones at your local mower repair shop, your local Sears mall store, or online at sears.com.
Use shear pins or shear bolts not regular bolts. The shear bolts are designed to break off so you don't tear out the front gear box.
Feel free to ask any other questions. Don't forget to rate this answer!
Jan 12, 2011 | Craftsman Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Plunge router manual
I have had incredible success over the years calling Sears product Help Line-usually Parts
-they have sent me numerous manuals for 20+ year old lawn mowers, rototillers, and snowblowers
-their after-market service makes me consider purchasing new products from them
...but I enjoy buying through auctions.....and hunting for manuals when I need them :)
-contact them at 1-800-366-PART (1-800-366-7278)
-they will be able to help or transfer you to the right place
best of luck
Oct 08, 2008 | Home Security
Garden Logo
Top Sears Garden Experts
Superior Maintenance
Robert Larose
Arthur
Are you a Sears Garden Expert? Answer questions, earn points and help others
