My lIfb washing machine TL RDW 6.5Kg is showing how error
    Top Expert:
  • Washing Mach... Master
  • 66,248 Answers
CONTACT THE MFG TECH SUPPORT .
Posted on Dec 08, 2019
6ya staff
SOURCE:
High RDW SD count mean
To what make and model of camera does your query refer, please ?
Jan 02, 2017 | Cameras
MayTag Neptune TL washer machine keeps showing error "od" with a loud beeping sound. It has had this problem off and on (usually after every nine loads), I have been using the magnet trick up and down
Sounds like your pump is clogged. Usually a dime or nickel made it's way throw the hose & lodged in the pump. Remove the back panel and remove the hoses off the pump. Two screws hold the pump in remove those & inspect the pump through the rubber flap
Dec 12, 2012 | Washing Machines
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl error op
You have lost signaling thru the Left Hand Lid lock or you could have a Lid Magnet out of posistion;
Google Neptune TL Washer FAV6800AWW
6 or so post down and I have service notes to help you troubleshoot.
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytage Neptune TL gives od error code. Tried unplugging the machine. Tried many things, but nothing is working.
Could be loss of signaling thru the left hand Lid lock;
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Mar 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washing machine, it runs almost all the way through they cycle but on the last spin cycle it stops and the digital display shows LO. Can you help me?
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you.
Google this Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
Mar 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Won't advance
richard_f777
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
