Washing Machines Logo
Jan Cooper Posted on Dec 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electrolux front load washer will not spin large loads, but will spin small ones.
Dan Apthorp
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 69 Answers
  • Posted on Dec 07, 2019
Dan Apthorp
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
69
Questions
0
Helped
17308
Points
166
Sounds like you have a belt that slips under load. May need replacing.
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Feb 16, 2008
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Anonymous
  • 184 Answers
  • Posted on Apr 05, 2008
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Anonymous
  • 207 Answers
  • Posted on Apr 20, 2008
SOURCE: front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Anonymous
  • Posted on May 05, 2009
SOURCE: Walking during the spin cycle
My GE front load washer model WCVH6800JBB have the same problem. I just purchased and installed it yesterday, 05/04/09. Just like everyone said... when it got to the spinning cycle it walked to the middle of my garage and all the connections in the back of the machine fell off. My husband checked the instruction... There are 4 nut bolts in the back of the machine near the rubber leg (level). You need to take them off and try to balance your machine again. My washer is running very smooth now. Good luck!
Anonymous
  • Posted on Sep 22, 2011
SOURCE: my front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Why does it always become unbalanced in spin cycle?
Kenmore Elite Top Load Washer - Unbalanced Loads ...
www.shopyourway.com > Manage My Life > Questions
Recently, the "LF" code has started to display and the soak cycle will not complete unless I ... Kenmore Elite Top Load Washer - Unbalanced Loads During Spin Cycly ... Would a bad outer tub literally cause the basket to become unbalanced?
Fix Unbalanced Top Load Washer - YouTube
? 1:21
https://www.youtube.com/watch?v=cVZIGhULzg0
Jan 17, 2014 - Uploaded by Carpe Diem
How to fix unbalanced high efficiency top load washer. ... I am having a MAJOR problem with unbalanced ...
Off Balance load in spin cycle - Sears ... - YouTube
How to get the clothes to spin dry in Color wash mode?
Program the machine for white wash and turn down temperature and duration manually, and tune up the sentrifuge program to maximum RPM.
It helps to use a machine with large drum and minimum 1600 RPM. Large diameter of the drum is more efficient than a small diameter drum at the same RPM.
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Washer making loud noise willnot spin cycle or drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washer will not spin out in any cycle
heatman101
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
2answers
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
