Washing Machines Logo
P
Peter walenceus Posted on Dec 07, 2019
General electric dishwasher model GDT695SSJ0SS with a dead top panel on the door no lights machine will not run power going to the machine and door and we have replaced the top user interface panel
Stephanie Baxter
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Dec 07, 2019
Stephanie Baxter
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
1236
Points
8
There's a screw at the top of the tail light cover. Remove that and pul whole cover straight out
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jul 14, 2007
SOURCE: Power to dishwasher and will not run
Check your thermal fuse. It will be inside the control panel, clipped to the control board somewhere. It's usually a white plastic square piece with two wires connected to it. The fuse should read a short. If the fuse is blown, you will need to replace it. If the fuse reads good, I would suspect you have a control board problem. Make sure you secure power to the dishwasher BEFORE you take any resistance checks, however. Even if the fuse is blown, you could still have live voltage on one side of the fuse. If you cannot find the fuse, there should be a tech sheet with wiring diagrams inside the lower kick plate below the door. This could be a tremendous help you as well. Let me know what you find.
Anonymous
  • Posted on Jul 12, 2008
SOURCE: asko dishwasher model 1475
Have the same problem with our asko 1475. In the past, we would disconnect the dishwasher and when we reconnected the power, it ran fine. This time it isn't helping!
Anonymous
  • Posted on Nov 10, 2008
SOURCE: Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Anonymous
  • 86 Answers
  • Posted on Jan 10, 2009
SOURCE: MAINS ELECTRICITY FUSE TRIPS WHEN DISHWASHER TURNED ON
Hi, I think you will need to check the heater or the wash pump, as these are the first things to energised. IOf yo could give me some more information then i could tell you where to after these things have been tested ok!
Get back to me......
Anonymous
  • 246 Answers
  • Posted on Nov 12, 2009
SOURCE: Are white front door dishwasher replacement panels available?
Absolutly! There is a website that allows you to do a bunch of stuff to the front of your dishwasher , including changing colors, without actually unscrewing anything. Check out www.applianceart.com. They do sell stainless metal panels for cheap there too.
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
2answers
Dishwasher wont finnish rinse cycle
can you provide the make and model number of your dishwasher ..........
If it is wiring fault
check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Oct 19, 2008 • Dishwashers
Everything lights up and can choose a program but when I shut the door dishwasher will not start
Hello;
My name is Peter. I am a retired field service appliance technician.
Locate your model number. It is either on the top of the dishwasher door or on the face of the dishwasher after you open the door. Since you did not provide a model number I can only advise in general.
Let's assume that your control board and the touch pad if you have one are fine.
1.) Door Latch Contact Switch - You will get no power if this switch has failed.
2.) Thermal Fuse. - You will get no power if this component has failed. It is normally mounted (Clip on) on the side of your control board assembly.
This component as well as the door latch switch can be Ohm out to check if good or bad.
Caution: If you elect to change the thermal fuse, ground yourself by touching something that is bare metal. Static electricity will knock out a board.
Go into the following website, plug in your model number (Left side), and you will see diagrams and part numbers of what you have.
Water Filters Lawn Garden Appliance Parts
Jun 05, 2015 • Dishwashers
Now power at all
Usually when you do lose power to the control panel one of the first things that you would check would be your electrical circuit breaker to see if one of the breakers had tripped. If you had done this and then assured that no breakers had shown a fault, on most dishwashers the electrical tie in is located on the bottom right hand side if you were facing the dishwasher. Depending on your make would depend on if you had a lower kick plate that you would have to remove in order to access the electrical tie in connection. Useing a multimeter you would first shut off the power at the electrical breaker panel and then disconnect the electrical wires. You would then turn the breaker switch back on makeing sure it is not hitting no metal at all which would cause the wire to ground if it did. You would then test the wire to assure you do have power going to the machine. If you did have power going to the machine your next step would be to turn off the breaker again and reconnect the electrical wires so that you can once again see if there are any lights or led's on the control panel that are illuminated. If you still had no lights showing your next step would be to check the door switch that is located on the inside of the door. I will await your reply before provideing further diagnosis as to your make and model number. If you have any questions message me those back as well.
Thank you
Rick
Nov 12, 2011 • Dishwashers
1helpful
Asko 1805 - inside light is on, none of the operation (front panel) lights turn on
Quite simple after all. If the main power button on the top left hand side of the door is pressed in (on). Whenever the door is openned their is a light in the DW which comes on like the fridge or oven.
Keeping the power button off turns the light off. For us this is good as we usually only close the door fully (catch catches) when we run the machine.This way we are not wasting electricity.
Dishwasher acts like it isn't getting power.
If you have power to the board and no power out to components then your board has failed. Will need to replace board. Part#154635501 and sugg retail is about$100.
Jun 09, 2009 • Dishwashers
2answers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Unit is dead: does not appear to have power
Hello chicagogunn,
Welcome,
You said,Your unit stopped working mid-cycle. You have verified that there is power to unit. Is there an internal fuse which could have been tripped? None of the lights on the control panel currently light.
There is a thermal fuse!
Go to this repair web site I listed below and you will see the diagram
1. Diagram Page 02 - CONTROL PANEL PARTS
2. The thermal fuse is, Item # 6 on the diagram.
3. Click on page two on the left at this site.
4. And then in the upper right corner it says Open This Diagram in a New Window
http://www.pcappliancerepair.com/model-display.php
6 8193762 Fuse, Thermal Electronic In-Stock $ 13.25
Let me know how you do!!
Huuum
Please remember to leave a rating!!!!
ALSO:
Here are four things that the repair manual says to check.
1.
Burnt or broken wires
Check for burnt or broken wires. This would include the wires on the timer and door switch. Also check the wiring connection where the main power connects to the machine.
2. Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a volt /ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician
3.Door switch
The door switch is wired in series with all components on the machine. If the door switch is defective, the machine will do nothing. Check the door switch for continuity
4.No Electrical power
Ensure that the proper voltage is being supplied to the appliance. Check the breakers or fuses that are supplying the power to the appliance electrical outlet. You can use a voltmeter to test for voltage at the electrical outlet.
Thank you Huuum
Top General Electric Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
