Question about Liebherr Refrigerators
Hi, my Liebherr 7082 312-01 fridge/freezer is displaying a flashing -7 for freezer for 24 hours. The food seems ok. Could the temp display panel be broken or is it the freezer?
    Top Expert:
  • Liebherr Master
  • 10,627 Answers
Possible bad temp sensor
Posted on Jan 04, 2020
    Top Expert:
  • Liebherr Master
  • 30,781 Answers
Measure the internal temperature and you will know.
Posted on Dec 09, 2019
6ya staff
SOURCE:
Anonymous
  • 290 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
Anonymous
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
Anonymous
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
Anonymous
  • 700 Answers
SOURCE: Freezer part doesn't freeze door was part open for hours
the coil inside of the freezer is probebly still frozen up with ice. Take a shop vac and open the freezer side after shutting the unit off and blow the air from the shop vac into the vents that are on the back side of the freezer until you can feel good air flow out of the very bottom of the freeezer. You can contact me and I will assist you if you need more help.
Posted on Feb 01, 2009
Anonymous
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
My s2655df fridge freezer is not working correctly,!the freezer and fridge don't seem to be no were near cold enough,,the freezer keeps flashing (on the screen were temp is displayed),(it flashes this _._...
I would say if this was a manual model, that it was your defrost timer. When you get a computer board involved, I'm just not sure.
Have you tried partselect.com ?
Feb 02, 2015 | Refrigerators
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Fridge freezer
HI jACQUELINE.well i reckon the fridges r a bit temperaMENTAL.:).Before u do anything well u can check weather u have ice build up on the rear panel inside freezer compartment.either way i would first turn it off for 24 to 48 hours.then remove bottom plinth panel (bellow the door).thoroughly clean condenser coils right to the end.then try u could get lucky.if it doesnt work then the problem could b inside the panel.def/heater,fan motor,t/stat,or the board.good luck Ali
Aug 24, 2012 | Refrigerators
I have a Liebherr No-Frost Premium, with the freezer at the bottom of the unit three years old. I've had a number of problems with the box. The immediate pressing one is that the thermostat seems...
For that problem, the electronics control board and the thermostat must be check. Since the display doesn't follow the control button and it adjust itself automatically without controlling, it's already sure that the control is the problem. Check first thermostat then electronics control board. Be sure that the door are tightly close.
It is a pleasure to advice you.
Jul 09, 2011 | Liebherr SBSes 74S2 Premium NoFrost
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
Whirlpool s20drww30-a/g we have inherited this side side by fridge freezer but the fridge does not seem to be getting cols temp constantly reads 2c, the freezer temp at -18 is intermittent and the alarm...
Hi Heather and welcome to FixYa. I am Kelly. It took me over an hour but I did find your manual online. I first had to realize this was a UK model. Your manual is here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgwpsrvifuhome001/DOCTYPE/IFU/DOCLANGUAGE/GB
You may have to go to his page first:
and enter this product code:
858615915000
Per the users manual there is a vaction mode and it is discussed on page 9 of the manual.
The alarms are listed on page 10 of the manual:
The Vacation mode shuts off the fresh food compartment completely and there is not a temp display. The icon is in the lower RH side of the display window and is sleleced with the menu button. Per the manual you should keep depressing the menu button until the Vacation icon is not longer displayed. (Icon is a beach lounger chair and umbrella)
Thanks for choosing FixYa.
Kelly
Jul 28, 2010 | Whirlpool S20DRSS33 Side by Side...
Fridge and freezer display shows ON and not
Hi, if the display is supposed to show the temperature of the fridge/freezer on the display then what appears to have happened is that the remote temperature bulb has come out of place. If you can get to it you may be able to put it back in place. You will have to start at the display and will see the temp. cable and follow it back to see where the bulb is now resting. If it is not exposed for you to be able to excess it, I would call asap from where you bought it as it is new and tell them about this condition! Keep me updated on this please.
Sincerely,
Shastalaker7
PS It would not be the compressors unless the unit is not cooling at all then you could have a serious problem.
Jan 17, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
43 people viewed this question
Top Liebherr Refrigerators Experts
Marvin
Marvin
Paul Carew
Lawrence Oravetz
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
