My toshiba (AW-1190S) washing machine lidlock cannot open ?
  • Washing Mach... Master
  • 10,749 Answers
    Top Expert:
  • 66,248 Answers
CALL YOUR LOCAL REPAIR SHOP THIS IS ONE BRAND WE DO NOT KNOW
Posted on Dec 06, 2019
2 Suggested Answers
6ya staff
SOURCE:
SOURCE: The lid of my toshiba aw-1190s top loading washing machine would not open what could be the problem
Sounds like it has been locked. Is the power on it on or off? It will lock the lid, as shown by a red light (normally). Switch the power off, and it should unlock. If not, unplug it and it should unlock itself. If it does not do that, it may be that the lock is engaged and the mechanism damaged. Let us know what you find out after turning the power off, or unplugging it.
Posted on Sep 10, 2017
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Sep 10, 2017 | Washing Machines
How to fix error e23 on toshiba washing machine. machine runs for a whikle and then stops
Error Code ( E-23 )--------Clean the LID LOCK sensor,its almost located where you can see the LID LOCK came OUT and IN or Moving--which is functions to LOCK and UNLOCK the door cover ( Symptom ++ the LID LOCK will moving OUT and IN),open all the cover ,take out the LID LOCK sensor,open the LID LOCK sensor case until you can reach the COPPER connector which is act as the SWITCH .CLEAN the COPPER with paper sand or anything possible but not to damage the copper.After all put it back to the place intact.Hope it work,Mine worked with this procedure.+++++Toshiba AW-SD120S COST=== FREE OF Charge ( Do It Yourself )
Jun 10, 2014 | Frigidaire Affinity ATF7000E Front Load...
My AW-1190S toshiba washing machine was showing error code E2-3
My Toshiba aw1190s shows error code E21. What the problem.. Tq..
Nov 22, 2012 | Washing Machines
Toshiba aw-1190s error code E7-4
MY WASHING MACHINE APPEARS ERROR 2 AND 3.PSE CONTACT 019-2450009 0R EMAILS EZALYIMTIYAZ@YAHOO.COM. ANY SUGGESTION PSE?
Nov 17, 2012 | Office Equipment & Supplies
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
