turn off machine, unplug network cable turn it back on with cable unplugged,if it clears error then you have a corrupt print job or dont have paper loaded job needs to print, clear your print queue or load correct size and type of paper print job is asking for
the error is a system error if the following error code is displayed. When an error has occurred, clear the error by turning the main power switch off then on.
These error type should be reseted by restarting the machine
CF1XX, CF2XX, CF3XX, CF4XX, CF5XX, CF6XX, CF7XX, CFAXX, CFBXX, 0xFBXX
It is resettable to enter simulation so .....
Press and let down "Clear / Stop", "Start" button on the left to darken or clear, then "Stop / Clear" "U163", "Start" appears "CLE" and there you hit "Start" other time and now.
You can try resetting the fuser error code by performing the procedure below:
On the copier type - 10871087 (may have to be in the job status menu first)
Once in MA mode type in - 163
Start
Execute
Start
You should then either cycle the power or the machine will cycle for you.
If this does not work you will need a new cleaning lamp for your fusing unit.
Hi anonymous, Firstly read your user manual. Secondly search online for "error code c3300 kyocera km5050". I did and therefore can't see any reason to spoonfeed any further.
