Question about RCA Televison & Video
My RCA Led39B45RQ, i replaced the main board to fix the power on problem which it did but now when i turn on the tv the picture is showing very color distorted
    Top Expert:
  • RCA Master
  • 76,204 Answers
After the main board replacement, there are some adjustments should be done. Sometimes, the firmware update too might be necessary. There are service adjustments too. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
Posted on Dec 08, 2019
6ya staff
SOURCE:
Benimur
Louie Role
  • 6966 Answers
SOURCE: Sanyo 42
Hi again,
Sorry bout the Live Session.
May I suggest something?
Pls try another signal source other than the indoor antenna such as a DVD or even an old VCR.
It is possible that what you are experiencing is video muting due to dirty antenna signal. If even with a stable known to be good video source (DVD) the problem persist, then it is a matter of checking the voltages as indicated in your service manual.
Hope this be of some help/idea even if the chat did not work out. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 02, 2008
mbranjo
SOURCE: distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Posted on Jun 09, 2008
Anonymous
  • 4 Answers
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Posted on Aug 03, 2008
Anonymous
  • 8 Answers
SOURCE: 5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Posted on Jan 30, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Posted on Sep 16, 2009
I have a RCA TV LED39B45RQ - I have replaced both the boards and still get nothing but a red light ! any thoughts ? Thanks
What boards did you replace? Not knowing what you did it seems tv set is dead and that it just may be a power supply issue, a common ailment.
Sep 05, 2017 | RCA Televison & Video
TV has red light but no picture. It appears to not power on.
It probably got zapped with power. Regardless of how it broke, the first place to start is the main power supply board. Some people repair the caps, which without looking more in depth at some of the troubleshooting forums, I couldn't tell you which one is most often the culprit. It looks like the power supply boards are going for about $25 on ebay, and I would feel pretty confident replacing that at that price.
If that does not fix it, something on the main board could be "crowbarring", or sapping power from power supply from where it is needed to boot up, however, that would only be a secondary test to making sure our power supply is a good one.
Sep 20, 2016 | RCA LED39B45RQ 39" LED TV 1920x1080, 60...
Rca hdtv will not power on. Is it Power Supply or Main Board?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2015 | RCA Televison & Video
I have a rca model 40LA45RQ that will not turn on. When you hit the power button the light turns blue but no picture or sound. I tried replacing the power supply board and that did not fix it.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 16, 2015 | RCA Televison & Video
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
Showing irregular colors are red green and yellow and doubles
Tv have a problems known as a picture convergence problems,it is dead.Tv have colors R,G,B lines are mis alignments in pictures,have colors shadows pictures or 3D picture look alike?Yes,than the tv convergence board it dead,tv must require replacement on the tv convergence board like 2 STK conconvergence ICS and some or all of it resistors too,to fixed the tv convergence board to solved tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Jul 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Question - What would cause the colors to be off..meaning..it looks almost 3D and with widescreen shows the black on the top and bottow bows into the main area of the screen. Any ideas?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.The tv convergence board must be replace all these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Dec 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
