Washing Machines Logo
gord Posted on Dec 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove the Timer from my Maytag A806 washing machine to replace it 1974 I belive
Jorgie the appliance guy
Level 3:
Top Expert:
  • Maytag Master 5,639 Answers
  • Posted on Aug 18, 2021
Maytag Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523367
Points
32630
5 Related Answers
Anonymous
  • 481 Answers
  • Posted on Jun 29, 2008
SOURCE: replacing timer
  • push the timer in and turn it counter clockwise. this should unscrew it.
  • if that does not work, check the back of the timer for a black plastic tab. pull it out to unlock the timer knob from the timer.
  • there are many different styles of timer knobs.
Anonymous
  • 61 Answers
  • Posted on Dec 18, 2008
SOURCE: Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Anonymous
  • 311 Answers
  • Posted on Jan 08, 2009
SOURCE: How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
Anonymous
  • 311 Answers
  • Posted on Feb 27, 2009
SOURCE: Maytag Washing Machine Cycles Out of Sync with Dial
ive fixed lots off washers over the years[15,000 service calls] and was careful while taking parts off if i wasn't fulmilure with that model,but most timers and knobs have a key way so the knob can only go on one way.if thats not true for you, try this.turn the timer shaft till the washer is at the end of the wash cycle.[finished the load,it would be the final spin ,maybe five minutes long.when thats done the timer advances to off]now knowing that thats an off position set on your knob and then manuly turn it to the off position of the next cycle if it wont run you did it. if not you will have to go to the end of that cycle and remove knob and set to next notch in the knob,until you find the sweet spot.hope this helps God bless,tom
Anonymous
  • 363 Answers
  • Posted on Aug 26, 2009
SOURCE: remove lid switch, which does not work
Found this online, should be what you need, Good luck,
Joe
http://forum.appliancepartspros.com/dishwasher-repair/8110-replacing-lid-switch-whirlpool-kirkland-washer.html
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
I have a new timer to replace a broken one and I can't get the of
THE TIMER KNOB CAP REMOVES AND THIRS A CLIP UNDER IT REMOVE CLIP KNOB WILL PULL OFF YOUR SEE A SCREW OR 2 REMOVE TIMER MAKE SURE THE WASHER IS UNPLUG FIRST REMOVE BACK PANEL
1helpful
2answers
Maytag neptune MAH3000aww washer, will not work on spin cycle. Over 10 years old, is it worth fixing? What will this cost to fix?
NEPTUNES HAD A ISSUE WITH THE DOOR WAX MOTOR SHORTING OUT BUT IT BURNS OUT THE MAIN BOARD.IF THE DOOR LOCK LIGHT DOES NOT COME ON REMOVE POWER THEN REMOVE SCREWS OFF THE TOP OF THE TIMER COVER AND TIP IT FOWARD. LOOK ON THE MAIN BOARD AND SEE IF YOU NOTICE A BURNT RESISTOR P-11 POSITION I BELIVE
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
No screws in the front of my maytag topload washer. do I acess the timer from the rear
Yes you do remove the rear plate by removing the back screws remove the knob off the timer if there is a nut holding it to the frame loosen it but do not remove until you take the back cover off when replacing the timer remove one wire at a time to keep them in order. Please rate if helpful.
Maytag A806 washing machine leaking from the center,under the tub
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
Timer on maytag washer
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
2answers
Noisy When Agitating
I belive on the maytag whers with the cork screw agitator, if your sure thats where the noise is comming from I belive the agitator is a 2 peice unit and you can not just change the dogs as you can in a whirlpool you have to replace the agitator.
Servis washing machine
There was a service bullitin on this model concerning the lid switch and this sounds like your problem. Maytag redesigned it because of excessive failures. The new switch kit part number is 12001908. I don't know if you would have any luck contacting Maytag with regards to repairing this for free, but you could check. For reference the bullitin they put out was TCL-0001-b. If you cannot get anywhere with them, it's not a hard fix. We should be able to walk you through it. Catriver..post back
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
