Question about Sewing Machines
How do i stitch backwards to finish/close the stitching on a Finesse M356 model sewing machine? Does it have this option?
    Top Expert:
  • Sewing Machines Master
  • 66,248 Answers
HAVE NEVER SEEN THAT MAKE OF MACHINE , SORRY LOOK AT YOUR OWNERS MANUAL
Posted on Dec 09, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
bargainbox
Hassy
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
Anonymous
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
sewtexas
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
Anonymous
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Sewing backwards
sewing backwards is primarily to lock the threads at the start of a sewing process ans so stop unraveling of the stitch
it should be about 1/2 " long so you start sewing 1/2 inch , reverse back to start then reverse and sew on as normal
finish of the stitch should be the same before you raise the foot and snip the cottons
Aug 03, 2014 | Elna Sewing Machines
My new Singer machine ("Curvy") purchased last week (3/2014) has a page on stretch stitches. The way the book is written, it lists Straight Stretch Stitch on the same page as Ric Rac, HOneycomb, and...
A zig-zag is also a stretch stitch. Usually, a "built-in" stretch stitch will stitch forward a couple and then stitch backward and then stitch forward again (time consuming and uses a lot of thread--but suitable if that's what you want). Whatever you are sewing, whether it is a seam or finished raw edge and the fabric is stretch, you will need to use a stretch or zig-zag. A straight stitch will pop the threads as soon as the fabric has to give.
You can test your stitches on some scrap fabric and see what looks best.
An Over-edge stitch is just that, just a stitch over the fabric edge. It probably would not be suitable for sewing a seam.
Apr 09, 2017 | Singer Sewing Machines
How to embroider with elna su electronic
There are a couple of Elna SU models, the Star Series SU is white with a blue top panel. Or the air electronic SU is a white machine and a dozen years newer (80's). Both have a disc elnagraph reader in a flap on top of the machine and sew a range of stitches involving either side to side stitch formation or side to side and forwards and backwards, albiet revolutionary when new but not what modern computerised embroidery machines can produce now. To use, you set stitch width and length dials to zero, then insert the black disc into the elnagraph ensuring you line up the disc with a little finger underneath. There should be a red marking on the disc and the shaft to assist with this. Press down until the disc clicks into place. Now turn stitch length to S for supermatic and width to 4 and sew. You can vary the stitch width to adjust stitch and the AE also has a little dial that elongates or closes up the stitch. Try machine embroidery thread for a silky stitch especially with satin stitch where the thread is close together. Also wing needles can be interesting when using the turkish hem stitch disc.
Dec 29, 2012 | Elna Sewing Machines
Why does my machine now only stitches backward, and no decorative stitches
You dont state what model of machine this is, however I have come across this problem mainly on Elna computerized machines and it has been exclusively due to failure of the driver chips on the processor board that control the stitch length stepper motor. You can confirm this by checking whether you can vary the stitch length as well as just the forward/reverse. Same applies to Bernina models, but I dont know about others. Either way, you need to have it checked by your tech.
Aug 20, 2012 | Sewing Machines
I cannot get my monogrammed letters to come out clear. what am I doing wrong?
Are you using interfacing or "stich and sew" type support under the fabric?
To get a good result you need to interface the fabric, and use machine embroidery thread to get a silky look to the stitching. If you are stitching onto linen then you can use a tear away stabiliser and go for a small sized needle, probably size 70.
Some machines may have a fine "stitch density" adjustment too that will allow you to stretch or close up the stitching to finesse how it looks.
However, if it seems to be missing/not fully catching the lower thread in some stitches, then your timing may be slightly out. Will it sew a wide zig zag okay?
Timing is probably best adjusted by a technician so if you try the above and its still not looking good, then take it for a service.
Oct 10, 2011 | PfaFF Creative 7570
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
My singer does'nt do dverlockWhat can I do ?
No sewing machine does a true overlock stitch, that is what sergers are for, they trim and form a stitch on the edge of the fabric using 1 or 2 needles and two loopers. Costs more for an additional machine but the finish is much more like a shop bought item.
tally_girl_14.jpgi
Some sewing machines have an overcasting or interlock stitch which looks like stitch 10 in this picture above. Your machine may have this stitch?
If not, does it have a three step zig zag? It looks like a zig zag but the needle goes into the fabric three times as it forms each leg of the zig zag. This stitch is great for neatening a raw edge and I use this a lot myself. Especially on wovens as it is always faster to seam with this rather than the overcasting stitch where the feed dogs move the fabric forwards, then backwards, then forward to make the stitch.
The sewing machine made overcasting stitch can be used to sew knit fabrics, attach rib around an neck line and neaten raw edges but it is always going to take longer than a serger and there is no trimming function so its never going to look like a shop made overlocked item. However, you can sew knit fabrics with a sewing macine with a bit of patience as long as the machine has some "Forwards/backwards" type stitches as these put elasticity into the seams - if you seam knit with a straight stitch, seams can break when under tension during wear.
And use a twin stretch needle and straight sttich to sew the hems, this looks a bit like a cover stitch and has a bit of give in it too.
Hope this helps you a little. You can find some good sewing general info on www.sewing.about.com or invest in a good sewing book. I refer to my Vogue Sewing Manual and my Singer Sewing Secrets often. Or take a sewing class, its a great way to learn new things, get enthused and have fun.
Apr 08, 2011 | Singer 3116 Simple
Singer Model 6212c only sews in reverse... Just brought this machine home today. Ha Ha, it only sews in reverse mode.
there's probably nothing wrong with your machine.
check and see if your stitch length setting is set to Stretch instead of somewhere between 2 and 3.
If it's in the stretch zone (below 0), it can sometimes sew backwards unexpectedly depending on what stitch you have selected.
make sure you have selected a straight stitch, and then select the highest stitch width and a stitch length of somewhere between 2 and 3.
it will most likely work fine.
Apr 02, 2010 | Sewing Machines
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
