SOURCE: Saw your post about Black and Decker MM525 Lawn Mower
With the Black and deckers, I think you just take the blade off and turn it over. That wil direct the grass clippings down into the ground.
SOURCE: craftsman 19" Electric CORDLESS 48 Volt Lawn Mower
i was mowing in light grass and hit a tree root. the mower quit, batteries are fully charged. can anyone suggest a way to remove top cover? I suspect that i'm going to be confronted w/a printed circuit board with several silicon controlled rectiviers on it. I'm a legally blind ex electronics tech.
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
SOURCE: toro self propelled 22 inch recycler lawn mower not picking up grass
is there to much old grass built up under the mower?did you damages the blades
